Hi guys,
just wondering anybody tried the boost p8 by United before. United its owned by Mobil now. This was breifly mentioned in the force induction section.
It got me thinking. If people is talking about converting to Lpg because of the fuel cost, why not use the United Boost 98? I called the box Hill Branch in Victoria and they wer selling it for $1.39/lts of the boost 98. Boost 98 got 10% ethanol in it.
I have asked this question on the on ther thread. Has anybody tried it long term? My bro said that Nissan engine are not compitable with ethanols. And theres no listing for Nissan as well in the United website. Hondas are not included as well.
FOe $1.359 its preety cheap compared to other 98 Ron fuels by about 8-10 cents i believe. Also since Ethanol is corrosive wouldnt be good to keep the engine clean as well? Like the Biodiesel as well it will keep the engine clean. Optimax Extreme got 5% Ethanol in it but its damn dear i think when i tried it a few weeks ago it was $1.50/ltr. But thats 100 Ron though. But is it worth it compared to the Unite Boost 98 and the Optimax Extreme and the Normal 98Ron and the Lpgs.
ANother thing is on the other thread they wer saying the engine has to be tuned to suit the fuel in ths case the ethanol. Couldnt we program 2 maps into the Power FC so when you use the boost 98 you switch to a specific map and switch again when you are using normal 98 Ron?
Heres the lin to Unite , it will show you where Boost 98 is available australia wide
http://www.unitedpetroleum.com.au/distribu...8-locations.asp
All this just tyring to reduce our fuel costs. See what you guys think.
Edited by stasis
https://www.sau.com.au/forums/topic/132781-boost-98/
  • Replies 70
I still think the issue with ethonol is the effects on the fuel system, pumps, injectors, seals, etc. I reckon a pfc tuned to use this fuel would be fine, but would everything else cope with constant use?
that we dont know. I think the government is dong trials in different states to study the long term effects on the cars at the moment. So... Im thinking of trying it on my next tank of fuel
https://www.sau.com.au/forums/topic/132781-boost-98/#findComment-2460596
Ive tried a few tanks of it, generally filled up when still had a qtr of normal BP/Mobil 98 fuel in the tank. It feels nice to drive, is responsive, etc....... once I put in half a tank with no other mix of fuel, and it seemed ok - but I decided at the time that I wouldnt do that again, as Id rather do a 50:50 mix to be "safe"r.
edit: shell 100 ron looks to be coming to SA soon - so I wouldnt mind trying a 50/50 of Boost98 from Liberty and Shell 100 ron fuel
Brendan
Edited by Tangles
https://www.sau.com.au/forums/topic/132781-boost-98/#findComment-2460605
Brendan
It could be the go. 50:50 Liberty/Shell. I've been using Liberty for a while and find it does drive smoothly,but if its better than Shell98 which is available on Mt Tamborine, I couldn't say.
As I've said before the Stagea is VERY smooth and responsive.
Time will tell :):)
Edited by 66yostagea
https://www.sau.com.au/forums/topic/132781-boost-98/#findComment-2460777
I assume everybody has read my posts on using Optimax Extreme 100 ron in the R33GTST for the last 8 months (35 tank fills) or so. It is 5% ethanol and I have seen ZERO effect on any of the components, that’s injectors, hoses, fuel pumps, fuel filters etc are all perfect. All I see is more power and less knock.
I seriously doubt that 10% ethanol would have any effect on the components either. But it is easy to check for, stick a new fuel filter on and use the 10% ethanol continuously for a while, say a month, 5 or 6 tank fulls. Then remove the fuel filter, cut it open and check for foreign matter. If there isn’t any, then I’d say you have no problems.
:) cheers :)
https://www.sau.com.au/forums/topic/132781-boost-98/#findComment-2460871
Wouldn't the concern be the effect of corrosion on fuel lines etc, rather than particles? Or are you saying the particles would be stopped by the filter?
Because my question would be how ethanol corrosion on rubber works anyway, because if it just liquifies it then you're not going to get any in the filter unless you've used it for a very very long time and caught sludge.
https://www.sau.com.au/forums/topic/132781-boost-98/#findComment-2460902
Hey SK, got a link to your thread? I wouldnt mind reading it.
They used to have 100RON BP Extreme here in rocky, now they dont, replaced with 95ron 5% ethonol blend :wub:
Time to learn how to use the search feature, try;
"Sydneykid"
"Extreme"
"Any date"
:ninja: cheers :dry:
https://www.sau.com.au/forums/topic/132781-boost-98/#findComment-2461836
What fuel lines are we talking about?
The steel ones? I don't believe ethanol has any affect whatsoever on steel.
The synthetic rubber ones? On the R33GTST that’s 5 really short pieces that are easily accessible;
Tanks/pump outlet to steel line
Steel line to fuel filter
Fuel filter to fuel rail
Fuel pressure regulator to steel line
Steel line to tank return
When I checked the fuel filter I removed #2 and #3. Any corrosion would show up as softness, loss of rigidity and thinner wall thickness. That’s a no to all three. Any flaking would show up as pieces trapped in the fuel filter. That’s a no to that one as well.
I have also removed, flushed and cleaned the injectors, plus I checked their flow and compared it to before we started using Optimax Extreme. Just in case something snuck past the fuel filters. Or the injectors themselves were somehow corroded or damaged by the ethanol. As you might have guessed, that’s a no to that one as well.
I haven’t measured the flow of the standard R33GTST fuel pump, but it still produces the same pressure (on the GReddy fuel pressure gauge) as it did before we started using Optimax Extreme. So that would indicate to me that some 2,000 litres of Optimax Extreme has had zero effect on the fuel pump
If I have forgotten anything that I should check, please let me know and I will gladly check it. I have asked Nissan why they won’t recommend ethanol, and the above were all the possible reasons they could give me.
:D cheers :D
https://www.sau.com.au/forums/topic/132781-boost-98/#findComment-2463917
Hi all my hubby started this topic in the forced induction section.
And as he stated we have both noticed the considerable difference with both our cars.
Not just the fuel consumption side but also performance wise.
I was using shell fuel then swapped to bp and I was only getting maybe 200k to a full tank I now get 350-400k a tank. And I do not drive any differently. I have used boost98 for nearly 6 mths and will continue to do so. Also my fuel filter was changed before swapping to boost98 and it was full of crap and that was from using shell and bp fuel, don't know what kind of condition the new one is in but when this one is replaced I will let you know if I have any sludge inside..
Anyway that is my 2 cents worth, I spose it comes down to the fact each to their own if you find something that works for your car then stick with it.
https://www.sau.com.au/forums/topic/132781-boost-98/#findComment-2468123
im trying the boost 98 on my next tank. One thing. My bor filled up my dad's HSV with the 95 United and i asked him any difference? He said its smotther ride. So just to let you guys know.
My theory is if this boost 98 is a pretty good fuel copared to the other 98 ron sucha as shell, Bos and Mobil. Why not use it.
@ advantages, less impact on the environment and you can hammer more cos you know your fuel is cheap. HAHAH!!. But thats me in the stage of denial soz guys i have to carcj this one cant help my self
https://www.sau.com.au/forums/topic/132781-boost-98/#findComment-2468505
Nissan continues to place a very high priority on effective environmental management and has taken a comprehensive approach to reducing CO2 emissions, developing fuel-efficient engines, highly efficient transmission systems, lightweight, high strength vehicle bodies as well as more aerodynamic vehicles with low air resistance. Examples of advancement by Nissan with this type of technology are evident in some recent new releases such as 350Z, Maxima and Murano.
Can my vehicle run on fuel containing ethanol?
Nissan vehicles manufactured from 1 January 2004 onwards are capable of operation on ethanol blends up to E10 (10% ethanol), providing the following conditions are met:
The fuel used (including ethanol-blend) meets the requirements of the Australian Fuel Quality Standards,
A credible history of servicing as per Nissan's recommended service schedule can be shown, and
Blending of the ethanol component to the petroleum component of the fuel has been properly made for example at a fuel refinery (ie there is no "splash"-blending of the fuel).
For Nissan vehicles manufactured prior to 1 January 2004, although capable of operation on ethanol-blended ULP, Nissan does NOT recommend the use of ethanol-blended fuel in these vehicles.
i hope it helps
https://www.sau.com.au/forums/topic/132781-boost-98/#findComment-2469529
i hope it helps
So what? we can use it? Not recommended ia a very general temr isnt it? Well can we acutally use it or not?! Comeon guys!! Just want to set the record straight.
https://www.sau.com.au/forums/topic/132781-boost-98/#findComment-2469847
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
