Ok, to work in conjunction with an aftermarket ems when upgrading injectors, is it better to run high, or low impedance injectors?
That is, either stick with the high impedence injectors on my sr20det and get larger ones from an s15 (relate to r33 injector setup), or should I get a fuel rail made up and run some low impedance injectors?
The reason I ask is because, if it's a lower impedance, then less resistance and therefore obviously higher current - therefore is it safe to assume that the injectors would operate a lot faster?
Or is this only the case in BIG horsepower engines, and not something I should worry about?
Cheers
https://www.sau.com.au/forums/topic/13284-high-or-low-impedance-injectors/
Hi PSIKO, never seen any evidence of hi or low impedance injectors being better or faster. It is the fuel feed system that matters, side feed injectors are way more expensive to buy, so we like to change to top feed.
Hope that helps.
well apparently this is so, but when you don't run any form of aftermarket management that can determine it, they all run under the same resistance and therefore same properties
later on you can set it so that the injectors open faster (more current, lower resistance) and upgrade the springs so that the injectors close quicker (needed with higher hp and rev's bla bla)
but basically for my needs, its irrelevant which I go for, only depends on how much I want to pay, and whether I intend to upgrade later (back-fed better for this)
therefore back-fed (top-feed) is what I'm going for :P
Would like to know how this works. My (limited) understanding is that electricity travels at the speed of light, and if you up the current to a circuit designed to operate at a specific amperage, all you do is risk doing damage.?????
anyone thow some light on this for me?
Cheers
Steve
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
