Well I've had one of geoffs bars on my line for about 8 months. The quality of the workmanship was top notch. Considering this 8 months includes a couple of outings to wanneroo raceway and the fact that these bars are fitted to some very quick victorian gtrs and gtsts, I'd say they hold up very well.
:huh:
https://www.sau.com.au/forums/topic/132859-hicas-lock-bar/#findComment-2463767
I made my own hicas lock up "kit". Re-use the rack with some machined up washers, slight mod to the motor, plug it back in and go driving. Works quite well surprisingly and the hicas light goes off as the car still thinks it has hicas working. More than 1 way to skin a cat eh?
Regards
R Dirty 3
https://www.sau.com.au/forums/topic/132859-hicas-lock-bar/#findComment-2465639
man i just tried to fit mine and i got give the wrong one from jshop soooo pissed i believe i got the r32 one as the rods dont fit into the bar and the hicas motor it self my uncle screwed the end tread on it so i gotta get that fixed so i can drive my car
need to go hunting morrow for a new bar hoping hyperdrive, xspeed or wilkos have something anotherwise im stuck with stupid hicas again grrrrrrrrrrrrrrrrrrrrr
https://www.sau.com.au/forums/topic/132859-hicas-lock-bar/#findComment-2465902
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
