Well I've had one of geoffs bars on my line for about 8 months. The quality of the workmanship was top notch. Considering this 8 months includes a couple of outings to wanneroo raceway and the fact that these bars are fitted to some very quick victorian gtrs and gtsts, I'd say they hold up very well.
:huh:
https://www.sau.com.au/forums/topic/132859-hicas-lock-bar/#findComment-2463767
I made my own hicas lock up "kit". Re-use the rack with some machined up washers, slight mod to the motor, plug it back in and go driving. Works quite well surprisingly and the hicas light goes off as the car still thinks it has hicas working. More than 1 way to skin a cat eh?
Regards
R Dirty 3
https://www.sau.com.au/forums/topic/132859-hicas-lock-bar/#findComment-2465639
man i just tried to fit mine and i got give the wrong one from jshop soooo pissed i believe i got the r32 one as the rods dont fit into the bar and the hicas motor it self my uncle screwed the end tread on it so i gotta get that fixed so i can drive my car
need to go hunting morrow for a new bar hoping hyperdrive, xspeed or wilkos have something anotherwise im stuck with stupid hicas again grrrrrrrrrrrrrrrrrrrrr
https://www.sau.com.au/forums/topic/132859-hicas-lock-bar/#findComment-2465902
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
