My little rant concerning QLD girls...
  • Replies 107
Oh jeez, you boys need to look past ur noses to way more important things, like chocolate and stuff. If or when you guys come out on Easter weekend, I reckon us girls should sit down and give you a seminar or something. Bel, don't wear shoes, maybe that will overcome that bit and I'll take your keys, so no retreating toyour car..........
hrm didnt read the whole second page so dont know if its been mentioned but........ move to perth. we have the hottest and nicest chicks in oz. (cept of corse all u lovely wonderful gurls who post on these forums but are unlucky enuf to be in another state)
but be forwarned we also have our skanks. really i spose its all the same everywhere u just gotta look harder. also dont make the mistakes i did. at 16 i was looking for a permanent relationship and have had a total of 2 girlfreinds (currently engaged to second) i missed a whole lot of fun. so get out there and remember ur only 16 u shouldnt even really be looking long term just yet. But if its gonna happen its gonna happen
Psiker
(prepares for flamings from qld gurls)
*sigh*
bel mate just talk to a girl like you would talk to a guy (just watch the profanity) let the girl get to know who YOU are dont try and be someone else. and you dont need an r34 to get the chicks plenty out there that like the r33 just as much
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
