Steve,
On the street my RE540S's (once warm) are bloody awesome. Put it this way, after fitting them the new grip levels helped my clutch die very quickly. Previously my 255 Falkens had taken the brunt through w/spin. New grip levels & minimal w/spin meant it was the clutches turn to cop it!
On the strip I've yet to make the most of them. Clutch slip & failure to heat them (no burnout) are the reasons.
Well had 3 runs 2nite. Not very happy, but oh well. First run 14.8 105mph. 2nd run 14.1 108mph and the 3rd 14.8 103mph. I think the main problem was the tyres on the back. I had re540s but it kept bogging down of the line. I was taking off with 5-6000 revs but still bogging down. By the time I got going it was down to about2500. My r/t were all aroud .4 to .5 Those tyres have sooo much grip
i ran a 14.8 when my car was stock, went back to the track last night with fmic, pod, 3" all the way and boost at 14psi. Had big boost problems, it kept bleeding back to 10psi, i'm thinking the waste gate actuator or the BOV are leaking. Still ran a 14.491 though which makes me confident i can break into the 13's with this setup.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
