  • Replies 65
Posted Images
Are these site trust worthy and is it in australian dollars cauz the prices seem too good to be true.
not sure about greenline, but nengun is in aussie dollars and i've bought a fair few things from them, so yes they are trustworthy :nuke: sometimes they take awhile to send the goods, but they are generally good with email responses, and their prices are the cheapest i've seen! :)
just a quick question about the safc2; i was reading that they can display boost pressure so could it be used as an accurate boost gauge?
im looking at getting one from negun also, how many people are looking at getting one? should do a group buy :(
from what i have read on this site i think that the safc is realy only any good if you dont plan on modding your car to much. they wont run much bigger injectors so if you are thinkng of upgradeing your turbo later dont bother as you will need injectors as well. the reason you see so many for sale again is because they have there limits that are passed quite quickly. but they are a good unit.
another cheaper option is to get one of the Jaycar digital fuel adjuster kits.. these are exactly the same and will do the same job if not slightly better. the jaycar unit has more load points than the apexi across the board but the later moddle safc2 has a full throttle setting which is said to be pretty handy. there was a group buy on these recently and the unit plus hand controler was selling for around the $100. for the DIY king well worth it.
here is a link to some more info. there is a lot of reading but most of it is on the boost controler so scim over that and have a read of the DFC.
http://www.skylinesaustralia.com/forums/in...showtopic=61207
this is correct, ive got one installed and now ive reached my power limits with my new aftermarket turbo and now need to get a power fc, fuel pump and injectors to achieve more power..
wont help too much on economy as it is tuned to decrease fuel ratios at over 60% throttle, and most of the time u drive the car at under that percentage.. this is how its tuned on mine anyways, depends on wat kind of tune u get..
either way, i was happy with it so far, increased a bit of power and overall performance, but like i said its limited to wat i want to achieve thats why im goin to be selling it soon and purchasing either a power fc or microtech..
Edited by MKDR33
They are definatly worht it. I had mine tuned this morning, First run 147rwkw with map all over the place. Then we played arround with fuel pressure and got it up to 165rwKw and a good place to start, 3 hours later managed to get a peak of [email protected] psi BUT massive spikes as the boost controller could not do it's job. So backed off to about 10psi and amanaged a nice [email protected] psi.
THE SAFC II made a hudge differance, and littel by little the power came up SO i think for $350 plus tunning, well worth the money.
Mods are, SAFC II, FMIC, Dump and exhaust 3", HKS pod, bleed valve boost controller, FPR, and a new pump, mine died.
here is the proof, as you can see the boost sux.
Edited by WogsRus
so it a worthwhile mod then? whats the average power gain using the safc2? seems some people get 10kw and other 30-40kw.
depends on ur other mods, eg intercooler, POD, exhaust systems, turbo upgrades etc.
does the safc2 display boost and is it accerate?
no it doesnt display boost pressure..
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
