  • Replies 91
Originally posted by GTS-t VSPEC
I had the demo ones last night at the cruise, showed them to a few people, but it was too disorganised to try and worry about taking orders last night. I'll attempt to get some pics up soon,
See'ya:burnout:
Weak excuse but cool:D
Cheers
Ken
Paul
Do you want the money up front before the shirts get done? If so, I will drop some money off at Works Auto.
Are the L sizes really big as not sure whether to get a M and or an L
Cheers, Al
