Group Buy # 2 Arospeed Adjustable Cam Gears
Do you think it would matter putting these on now if i'm not gonna get a dyno re-tune for a while just yet? I know not much difference will be noticed, if at all until its tuned. But could it actually be worse to have them on untuned for a while?
Any help woud be much appreciated guys, thanks.
Just put it on if you know how to and leave it set to Zero.
It will be EXACTLY the same as the standard Cam Gear if on Zero.
  • Replies 223
Posted Images
anyone else from perth getting some
cant wait too much longer
feel like a kid at chistmas :)
Well not Perth but Bunbury.
An I know what you mean - problem is I am waiting for Santa to come in big time - uprated turbs, management, oil cooler, injectors, baffle kit all on the way as well as the timing gears.
They say patience is a virtue.
Have fun
Recieved my cam gears today..
Thankyou very much..Let me know if there is another group buy and I will most probably get more for my other engines..
cam gears arrived today ty heaps for your assistance with this group buy you have done us all a huge favour . Let me know if there is another group buy.
3 cheers for the cam gear king!!!! :D
Edited by rza1
RECIEVED THEM AGES AGO THANKS MAN HOW DO I LEAVE TRADER FEED BACK FOR YOU?
OH AND IF ANY1 WANT TO BUY MINE I NEED TO SELL THE PAIR PM ME I SOLD MY CAR LOL
THEY LOOK GOOD BUT! LOL
Edited by SXY
