PEEPS PETER BROCK HAS JUST PASSED AWAY ANOTHER ONE OF AUSTRALIA"S ICONS IM HOPING ADMIN WILL PUT TOGETHER A REMEMBERENCE CRUISE FOR PETER BROCK AND STEVE IRWIN LATER ON DOWN THE TRACK TO SHOW OUR RESPECT TO THEM AND THEIR FAMILY"S . RIP STEVE IRWIN & PETER BROCK TWO LEGENDARY ICONS!!
Edited by --{TRYDIS}--
https://www.sau.com.au/forums/topic/133486-peter-brock-rememberence-cruise/
  • Replies 42
what is?
that reports are that he hit a tree
that reports say "someone" crashed
have a look and find me concrete evidence its him
that just annownced it on 2gb radio one of the oldies at my work is stuk to that radio lol
Jesus mate!!! Give him a minute to rest at least FFS.
sorry boss didnt meen to offend anyone just wanted to show respect but your right so a few minutes silence for brocky RIP MATE!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
