ok guys and gals here it finally is DZNUTZ came to my joint this arvo and i finally got to see the car and i am still speachless(my first R34 up close and personal)
and yes he is going to calder with me tomorrow to give her a run
there are 13 pics, and 2 vids 1 is 300k odd and the other is 2 and a bit meg
brad :D
pic1
pic2
pic3
pic4
pic5
pic6
pic7
pic8
pic9
pic10
pic11
pic12
pic13
The videos will follow below, once i can upload them somewhere with my dodgy dial up ;)
https://www.sau.com.au/forums/topic/13363-dznutzs-r34-pics/
yeah i just saw the comparrison pics...well after 2moro night we should be able to post a pic of his times and results etc from the track that alot of them have been sking for......conroy reckons, the car would be pulling 300+kw easy....i wouldnt have a clue about kw etc hehe but i beleive him just by looking at it
https://www.sau.com.au/forums/topic/13363-dznutzs-r34-pics/#findComment-257337
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
