Stupid thing didnt attach my message. so here it is again
Hey man or anyone else that can help,
Found two 33's that seem way to good to be true in QLD so wondering if you could run these VIN's through your FAST for me.
1.VIN: 6U9000ECR33130992
2.VIN: 6U9000ECR33101704
Cheers
Hey Dezz,
Can i be a real big pain in the ass and ask you to decode what you can for both of them?
Cheers
Number 1
1997 (feb) R33 GTS-T M Spec
Manual
Black
2WD
HICAS
GGKBRTFR33VDA-E--A
G - 2 door coupe
GK - RB25DE(T)
B - 2WD
R - Same on all R33's
T - M spec
F - 5 speed manual
R33 - Obvious...
V - Forced induction (GTS-T)
D - Not sure
A - same on all 33's
not sure about the E
but the last A means you have active LSD, and no ABS
Number 2
1996 (jan) GTS-T M Spec
Manual
Sonic Silver
2WD
HICAS
GGKBRTFR33VDAAALCA
G - 2 Door coupe
GK - RB25DE(T)
B - 2WD
T - M spec
F - 5 speed manual
R33 - Obvious...
D - Not sure
A- not sure
A - not sure again
L - Not sure
C- not sure
A - Active LSD, no ABS
it definitely appears that the 2nd car has a shit load more options than the first....that may just be things like the CD player etc, and maybe a GTR wing
Would be fantastic if someone could check a VIN for me :D
6u9000ecr33060296
cheers
z
here you go mate. also, check your PM inbox....
can some plz check mine
6T91MPV97Y2CZP014
thanks in advance
no idea what that VIN number is from....
6u9000ecr33060296
cheers
z
here you go. you were right...it was an auto...built in feb 1997
Edited by SKY031
Hmm, knew that beeping sound in the cabin when the car is in reverse was for a reason :)
Any chance of decoding the last few letters of the model code - GGKBRTAR33VDA-EJ-A?
Also, what colour is KR4 supposed to be?
At least I now know which cams to get :D
Thanks heaps mate - you've been a big help...
KR4-Sonic Silver
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
