Last of all my parts. Make a close offer and it might be yours
Pair z32 afm's with plugs. Work fine. SOLD
Cibie super oscars driving lights- Pair spot beam $220
Front and rear strut braces - front is used couple months, rear new SOLD
2" Autometer boost gauge SOLD
Greddy Profec electronic boost controller SOLD
2" Greddy mechanical boost gauge $100
Rollcage 6 point for 32 coupe $525 with backing plates and all bolts
Gaurd plastic liners and windage tray in EC off R32 gtr $200 As good as SOLD
Rear 32 bumper $10
Gtst bonnet with vents SOLD
GTR turbos in EC $450 with actuators
GTR turbos pair one blown suit highflow $100 SOLD
Blitz Access ECU for R32 GTR $250 suit standard injectors/afm's
Pair R32 damaged doors with internals /electrics $40 no glass
Glass for R/H R32 couple door SOLD
Glass L/H R32 coupe Door with dodgy tint $15
R/h mirror $40
Transfer case out 32 gtr, removed due to damaged g/box input shaft SOLD
comes with gtr g/box with damaged case and input shaft. Good internals
Pair pod filter extensions SOLD
Set carpet mats for 32 $60
Gareth
0417370869
The paint on the bonnet is rough hence the $50.
There is no brand name on the cage but if you could tell me the exact difference between all of the 6 point cages out there I would like to know as they just seem to be different colours. I can put a sticker of whatever brand name you want on it if you like.
The rear bumper is grey.
SOLD bonnet and Autometer gauge.
Drivers window and mats awaiting pickup and payment tomorrow.
Make some offers on the other stuff guys and girls
R/h mirror $40
This is gunmetal?
RHS i assume you mean drivers side, correct? Im after a passenger side gunmetal mirror setup
Cheers
$200 for the greddy boost controller. Will work 100%. Came on a gtr I repaired and changed it back to stock before driving the car.
Sorry don't have a lh mirror.
The turbos are only turbos and actuators and you could also have the stock dumps if you want them at the same price. Their up there and if they sell it is good but if they don't I know their excellent condition and I'll keep them for a spare set.
Gareth, I'll take the blown turbos mate. Time for a project. Also want the gearbox/transfer case. I'll be coming through that way Thursday if you can have them at work.
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
