Hi all,
I have a datsun 1200 ute running (used to anyway) with a CA18DET and a Stinger 4424 EMS (I am using the stock CAS and have tried both the new and old one, and I am using a map sensor). I swapped my old CA for a fresh version recently and now I cannot get it started. To date i have:
  • had the injectors cleaned
  • changed the fuel pressure regulator for one that I know works
  • checked fuel pressure
  • changed the wiring to all ignitors to make sure they fire with a strong spark
  • changed the spark plugs (NGK iridiums)
  • checked to make sure all injectors fire, as well as all spark plugs
  • checked base timing
Everything in the list is ok except for the base timing.
The timing should be 15+- 5 degrees BTDC.... to check this with a stinger EMS, you set the base timing value to locked, and then (i am using an inductive timing light), then check the timing. As per Timing.jpg (post-6655-1158020512.jpg) , the reference point when looking at at the front of the engine is on the top right, however the light is flashing and marking the timing to the left.
As per the s13 engine manual (post-6655-1158022660.jpg):
I then, turned the engine over until the cylinder head is right at the top of the compression stroke. The timing marks on the pulley then lined up correctly with the timing reference point....
I removed the cam cover and as per the above diagram, the two white marks on the cam gears were in the correct position, and the number of teeth between the marks was correct. See post-6655-1158022222.jpg
They only thing I didnt do last night was remove the pulley and bottom timing cover to check the position of the crank and the marking there......
My question is, what could be causing the timing to be so far out....
https://www.sau.com.au/forums/topic/133952-ca18det-timing/
my tuner told me: when using your timing light dont lock the little U clip thingo, keep it open but let it hang off the signal wire.
i found that the difference this made was a -10BTDC, i set my timing to 17 with it locked and it ran like shit.
later when i found out to keep the clip open it was on 6!
https://www.sau.com.au/forums/topic/133952-ca18det-timing/#findComment-2484238
What U clip thing is that?? I am locking the static timing in the computer (which is what the manual and site admins claim you need to do to check the timing).
https://www.sau.com.au/forums/topic/133952-ca18det-timing/#findComment-2484411
Joe's referring to the sliding clip that closes the inductive pickup around the trigger wire.
The timing is way too far advanced. If the CAS is like RB series ones, it should have a locating half-moon key on the ex camshaft. However, they are prone to snapping off, which allows the CAS to installed in the wrong position.
I suspect that the locating teeth are 1 set out. Carefully withdraw the CAS, and rotate its shaft counter clockwise about 20 deg, then re-install. That should get you close.
https://www.sau.com.au/forums/topic/133952-ca18det-timing/#findComment-2484503
they are a common prick of a thing...i broke god knows how many in my old sil80 with a ca. Gave up on the thing and put an rb20 in it instead :D
Need to keep the pivot point greased up all the time and that the spacing is spot on and no excess pressure is being applied to flex the drive.
https://www.sau.com.au/forums/topic/133952-ca18det-timing/#findComment-2484541
Thanks guys!
Ill have a look - from what I saw last night I was pretty sure that the half moon was still on the CAS and the cam gear....
however, should the half moon in the CAS come all the way to the very edge - or is it sunken inside about halfway down the shaft?
And ill see if I can rotate the sucker and put it back in! thanks!!!
Cheers,
Scott
Edited by banger
https://www.sau.com.au/forums/topic/133952-ca18det-timing/#findComment-2484842
From what I could tell from last night the half moon was still on the exhaust cam so there is only one way we could put it in.
Is there any other way for the timing to be this far out without it being the CAS? Also does anyone know if a rb25det CAS will work in a CA18DET????
https://www.sau.com.au/forums/topic/133952-ca18det-timing/#findComment-2484878
So I checked the cam gear - and the half moon is definately still there... I compared this to the old engine that I took out, and the alignment of the half moon in comparision with the white mark on the cam gear is exactly the same - however, the half moon on the old engine is missing...
So could someone have deliberately broken this off so they could adjust the timing or is it likely that the CAS is stuffed (but I have two, one from the old engine which was running and the new engine, both yield same result).........
https://www.sau.com.au/forums/topic/133952-ca18det-timing/#findComment-2487686
RB25 CAS runs 6 cylinders, CA18 is only 4 cylinders!!
You're both absolutely positive that both camshafts are aligned correctly with each other and the crank. I happen to have a 4-cylinder CAS, which I purchased by mistake (well, I was told it was a RB20 unit). Slip me a few $$, and I can send it to you.
https://www.sau.com.au/forums/topic/133952-ca18det-timing/#findComment-2488028
Yea, We measured the timing with the timing light on a lead between the 1st coil and sparky.
are u taking the timing by putting the induction clip thing on a lead between coil pack 1 and sparkplug number 1?
Ive found with CAs the loop on the loom can give incorrect timing.
https://www.sau.com.au/forums/topic/133952-ca18det-timing/#findComment-2488213
Just found out some extra info (I have read this a couple times before)
All Nissan Crank Angle Sensors need to be re positioned.
Nissan Sensors are normally set to 60 deg BTDC.
The ecu requires the trigger sensor to be positioned approx.
5 - 15 Deg. BTDC.
If the engine is fitted with a Distributor the Rotor button(if driven via a gear) or optical sensor or disk needs to be repositioned (if no gear drive) .
So i need to remove the locator on the cam gear so I can reposition it from the 60 it is now to 5-15 BTDC
https://www.sau.com.au/forums/topic/133952-ca18det-timing/#findComment-2488271
Why would you want to break the CAS drive off the exh cam? Generally when this happens you need to replace the cam as the timing jumps all over the place without a solid drive. Why don't you just undo the 3 bolts holding the CAS onto the timing cover and turn it until you get the timing reading your ECU is expecting. Then mark it and drill/tap 3 new holes in the timing cover to locate the CAS in the correct position.
https://www.sau.com.au/forums/topic/133952-ca18det-timing/#findComment-2489261
From memory the notches on the CA are (in degrees)
-5 0 5 10 15 20
My RB goes up to
0 5 10 15 20 25 30
One issue I had was I was setting the engine/cas to run 15 degrees which is normal - but autos require 20 degrees on standard ecu :(
JK
https://www.sau.com.au/forums/topic/133952-ca18det-timing/#findComment-2490669
just a quick cheak first up, make sure the engine itself is correctly timmed at tdc, make sure its true tdc, dont go by markings as such, just make sure the motor comes on compression number 1 and then cheak marks, keyway's on the crank couldve sherred off or distored, just be sure
https://www.sau.com.au/forums/topic/133952-ca18det-timing/#findComment-2491151
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
