Hi all.
So i know what each is, but how do i dignose it. I keep thinking i keep on hearing things in my R33.
How does one tell if the engine is knocking or pinging. I have fitted an SAFC II and i hardly get any knock maybe up to 15 or so. The car pulls HARD and EAVEN all the time, but somethimes i swear to god i am hearing something like knocking or pinging, but the car does not stumble or anything, no missing, no smike nothing. ( hard to tell with 3.5' exhaust and HKS pod)
So how does one tell by ear if anything is happening. What noises can you tell from, and symptoms.
ALSO how do i check timming, i have a series 1.5 so a series 2 ignitor on coil, no idea how to connect things up.
What are the timing setting suppose to be at idel ect????
HELP ME FROM GOING INSANE
Edited by WogsRus
https://www.sau.com.au/forums/topic/134153-knocking-and-pinging/
Knocking and pinging is generally caused by improper combustion in your engine, called "auto-ignition."
An internal combustion engine runs properly when the spark-initiated combustion wave expands rapidly but smoothly across the combustion chamber.
If the gasoline-air mixture auto-ignites somewhere in the cylinder (other than at the spark plug) just after spark ignition, the auto-ignition combustion wave can interact with the spark-initiated combustion wave, causing the vibration we hear as a knock or ping.
Increasing engine load, temperature, compression, spark-advance, air-fuel ratio, combustion chamber deposits, and decreasing altitude all increase the tendency for an engine to knock. :(
if your car is pinging/knocking its not good. Its something you should get checked out man. the human ear cannot hear about the first 10% of the sound that is made so if you can hear it over the exhaust pod than its pretty bad. If you got a Power FC I think there's a function where you can make it flash the engine light when its pinging/knocking???? Good luck man.
well the car is runnign stock boost and intercooler but new pod and exhaust, i am not saying my car does knock or ping, i simply WANT TO KNOW what they sound like and how to pick it ip if it does do it.
SO SOMONE tell me please.
I know what they are and what happens to the engine when it goes wrong, but HOW do it pick it up by ear.
THANKS.
BTW My safc II has a knock setting, it never goes higher then 15 or so.
Edited by WogsRus
If u can hear it pinging will sound like a box of matches ratling in the background very faint, then sever knocking is basically that, like a cylinder went knock on the side, well thats my interpretation. I drove around for 2 days wihtthe pining box of matches sound and it was real quiet so i thought it wasnt to big a deal to be urgent and then i busted a piston. ended up buying a new engine. Get it checked if your in doubt by a good workshop.
Thats my point, i have a 3.5" ehayst and a HKS pod with bellmoth intake, and at 4000rpm, no idea what is what, everything makes noise.
I have a timing light now and will check the timing this weekend.
Will pinging be notice by performance, ie losst or a miss or something
Listen to a loaded up mitsubishi express van go past in a gear too low for it. That's pinging. It's a metallic kind of rattling. I can hear it in my car but my exhaust isn't that loud and I don't have a pod. It's easier to hear with the windows up.
It's the kind of sound that someone needs to point out to you. Once you know it you know it. Hard to describe otherwise.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
