I have 1 pair of spacer with bolt pattenr 5x114.3 it came off my R32 but I dont need them anymore
ask in 70$ US + shipping
Are these bolt on with their own fixed studs or the sandwich type that just use the wheel nuts to hold them on behind the wheel?
Also thickness? Plus where are you so we can determan shipping costs?
Cheers
https://www.sau.com.au/forums/topic/134271-fs-spacer/#findComment-2493381
Cheers
Yep they use wheel nuts to hold them.. just fix and bolt them up and put your wheel back thats all! its about 1inch 1/4
they look like that (but not chrome)
https://www.sau.com.au/forums/topic/134271-fs-spacer/#findComment-2496164
  • 4 weeks later...
so ur selling 4 of these spacers.
I can offer u $50 AUD for them delivered to melbourne
Idiot...
Firstly he is selling 2 not 4.
Secondly he is in in USA hence asking $70 US. ($94 AUD)
Thirdly your pissy offer of $50 not even cover postage.
In what magical land do you think someone would give you a set of spacers for free you knob... Its a pitty people like you own skylines it gives us all a bad name.
https://www.sau.com.au/forums/topic/134271-fs-spacer/#findComment-2579290
Idiot...
Go buy some tissues and have a cry idiot,
https://www.sau.com.au/forums/topic/134271-fs-spacer/#findComment-2579956
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
