if there what i'm thinking of you get get them at auto barn, they have them on ns.com in the trader section where autobarn advertises.
there made by gizzmo...
http://www.nissansilvia.com/forums/index.p...howtopic=137329
https://www.sau.com.au/forums/topic/134464-cooling-spacers/#findComment-2501073
I don't see whats so funny about phenolic spacers? Anyone want to put some input instead of saying "POS" or "Junk" with no substantiation?
Its not hard to burn your hand on the plenum on a warm day. Makes you wonder how hot the air becomes again before entering the cylinder.
Here's some info;
http://www.outlawengineering.com/index.html
https://www.sau.com.au/forums/topic/134464-cooling-spacers/#findComment-2501669
Not disputing that it doesn’t work, but Outlaw Engineering’s R&D seems limited to me. The extent of their reported testing was limited to inlet manifold temps & for short burst of power from the engine (ie. dyno runs & 1/4 drag). There's no mention regarding engine temps or manifold temps after a track session or daily city driving.
My initial & main concern would be where does that excess heat go??. Their response in the FAQ, implies the trade off is an increase in water temps.
Personally if your after a cooler air intake mod which, primarily what this gasket is, a well thought out CAI &/or intercooler water spray kit would be a better bang-for-ya-buck for performance gains....just my 2c.
https://www.sau.com.au/forums/topic/134464-cooling-spacers/#findComment-2501867
Yeah but it makes you think twice about intercooling. I mean you can have the best intercooler in the world to give you ambient charge temps but if the air still increases by 20-50 or more degrees before entering the cylinder due to the toasty plenum and runners, then it makes you think doesn't it?
I don't think the excess heat is an issue. As if the plenum would radiate heat effectively anyway. Thats the coolants job.
https://www.sau.com.au/forums/topic/134464-cooling-spacers/#findComment-2502086
How does a gasket stop radiant heat?
Thats why i say - load of sh|t.
You cant stop radiant heat just by using a gasket. You would be very silly to assume that would be the case.
On thier website... thier "racing" results of...
To summarize, the car was ~0.1 seconds quicker and ~1 mph faster, all with a .073 second slower launch.
Are a total load of crap man. Come off it. Thats a as much affected by driver than anything else.
Laying claim to a "bees dick" in performance on something thats driver dependant is absolute crap
https://www.sau.com.au/forums/topic/134464-cooling-spacers/#findComment-2502098
Cmon Nismoid. Have an open mind. This stuff isnt black magic like pills in the fuel tank or some magical spark plug. You haven't tried them yet so the way you laugh it off is bees dick theory too. Nothing wrong with thinking a gasket can help insulation. Think about a polystyrene vs steel cup. If you google phenolic spacers theres plenty of info to be found. Here's one such article;
http://autospeed.drive.com.au/cms/A_0401/article.html
(Yes seems the performance data was taken from here but the Manifold Temp data is what is interesting).
The relationship of how the plenum's temperature affects the air of going into the cylinder is what interests me.
Edited by Busky2k
https://www.sau.com.au/forums/topic/134464-cooling-spacers/#findComment-2502139
I have an open mind, but i can see a gimmick when presented infront of me.
If you think that a gasket will alter intake temps, good luck.
If you also think on a turbo'd car that heatsoak is a super massive problem, good on ya :D
The article you linked has excatly the same poofteenth of gain as the original link... surprise... as its the same "data" that they are using.
Its interesting because if you look at the bottom of the article, it links you to the outlaw website :)
Funny that.
As this is ALL based on ONE website thus far.
Do you have any original links? Something that isnt a direct rip of the outlaw site?
https://www.sau.com.au/forums/topic/134464-cooling-spacers/#findComment-2502149
As I mentioned, google phenolic spacers and theres plenty of info to be found. They are quite popular mod on some cars like the MX6 etc where the N/A boys are looking for every last hp. Also it seems you can get spacers for even carby v8s etc. I'm gonna do a search tomorrow to see if I can find any independant links/forum reviews. Oh and btw, yes heatsoak is a problem in turbocharged cars, why would you say its not??
Found a few quotes here from various posts in other forums (not websites lol);
"They work good I had this gasket on my turbo civic. droped temps a good bit on manifold. After dyno runs it was still cool to the touch unlike a stock setup that gets real hot"
"My friend has one a boosted civic si. After hard runs with the car, you can place you hand on the intake manifold and it is close to outside temp. Seriously, it was cool to warm depending on how he drove the car. Before the spacer, you could not touch the intake runner near the cylinder head after hard runs. I'm sure it just helps keep the intake air temp down. seems to work pretty well."
"Enthalpy can attest how well it works. On the dyno, it was cool to the touch, even after repeated WOT runs. It wasn't even slightly warm! Try that with your standard paper or composite gasket!"
"To ground this conversation into a serious dicussion, my friend has an intake manifold spacer on his Integra.... He said it reduces intake manifold temp like 30 degrees or something, and actually shows a noticable difference in intake air temps."
"First comparision is coming right off the street and making a pass with no cool down. Before the pass, temps were at 147F and they were down to 100F crossing the finish line. Very similar conditions with the spacer, EGR delete, and TB coolant delete. Before the pass 107F; 89F after.
The next comparision is with the car being cooled for an hour. Before the pass, without the spacer, was 127F. At the finish line, they were down to 87F.
With the spacer the temps were 86F before and 77F after"
"I used the Hondata spacer/gasket on my last car (03 Civic Si) w/o problems. I'm not sure how hot the IM gets on turbocharged cars, but it helped that car tremendously. The IM was too hot to touch before the spacer, and afterwards, you could rest your hand on there for as long as you wanted."
There is a shitload of info out there. Granted some of these quotes these aren't all that scientific and are also bloody Hondas but I cant find a single post who said they are shit after buying them....
Edited by Busky2k
https://www.sau.com.au/forums/topic/134464-cooling-spacers/#findComment-2502153
yeah they stop the heat from the head to the inlet.
already tried waterspray not allowed to have it as it drops liquid on the ground and in a circuit race that aint good.
also tried that c02 cryo stuff that was a waste of time but prooved it would be good for a drag but not a circuit.
and in a race car that 0.1sec could mean coming 2nd instead of first and for the small outlay if it comes out to be true then it was money well spent wasnt it.
ppl that call bs and junk without even tring it are tossers and need to grow up i reckon.
the r32 gtr's already have 250awkw but restricted to 27mm inlets in the turbos so usless above 6300rpm so every bit of power helps them, already have a decent FMIC and piping, dry ice water to air setup would be good but the xtra weight might offset the gain though.
again thanx for those that actually had something to contribute.
SSS_Hoon
https://www.sau.com.au/forums/topic/134464-cooling-spacers/#findComment-2502156
Because @ 20+ psi/8000rpm... i wouldnt call the air... "idle" exactly.
You do the maths. See how much of that air actually gets "heated" in its travels... come back to us with your findings :D
https://www.sau.com.au/forums/topic/134464-cooling-spacers/#findComment-2502164
This thing is a load of horse shit. do you hava any idea of how fast the air travels trough the pinping, the only reason the intercooler has so much effect on the temprature of the air charge is beacase it effectively increases the surface area of the charge. instead of using this sort of horse shit spacer youd be better off wrapping the piping from the intercooler to the plenum with the stuff they wrap house hold airconditioner pipes (insulates the piping ie prevents heat from the engine heatin up your cooled charge. even if you dont do that the velocity of the air through the pipes is way to high to pick up heat effectivly.
https://www.sau.com.au/forums/topic/134464-cooling-spacers/#findComment-2502187
These are usually used on carby motors to prevent the fuel i the carby boiling after you shut the car off. I would imagine that most of the heat in the inlet manifold would came from the surrounding underbonnet heat, not through the transfer of heat from the gasket surface, however if you could reduce your engine bay temps enough so that the head is heating the manifold then there may be a very small gain, but water/math injection would work about 50 times better i would imagine.
https://www.sau.com.au/forums/topic/134464-cooling-spacers/#findComment-2502224
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
