  • Replies 92
Good news all, your cats have arrived! That means balance payments are now due and your cats will be posted as soon as I have the $$$
Please PM me with a postage address if you have not already done so.
Also this is the first time I have tried doing a group buy here in conjunction with aus300zx forum members (being a Zed owner myself), it's definately something I would like to do more often where possible as more buyers means better pricing! If you're happy with the cats and other aspects of the group buy, please give me a good review so as we can continue to do this kind of thing in the future.
:P:P
Hi guys, just a heads up we're trying to get a GB happening on metalcat hiflow catalytic converters on the AUS300zx forum. The thread is here
clicky for anyone who wants to check it out.
Basically we're looking at $560/pair delivered anywhere in AUS for the 200 cell, stainless, warrantied and street legal "metalcats" that have been advertised in Zoom etc lately. RRP is usually around the $350-$380 mark.
Please post in this thread (I'll check back regularly) or the one linked to above if interested.
Cheers
Guys we have a problem with delivery that is going to mean you don't get your cats until the end of this week.
Basically what's happened is wednesday arvo (when I sent out PMs) I arranged for TNT (the couriers) to drop the consignment off to me on thursday. Thursday came and went with no delivery so I called again friday to ask where it was and got told that yes it was booked to be delivered and I would have it by 5pm friday at the very latest. Guess what friday came and went and still no cats, and nobody in domestic freight again until 8am monday morning (today). So 8am monday morning I call TNT with the intention of picking up the consignment myself and posting out this morning, only to find after roughly an hour on the phone that the driver had messed up when they copied the con number down and the cats have been returned to sender. This was confirmed by a call from PSI shortly after my chat with TNT...
Anyways they have been sent again and should arrive at the depot and hopefully get to me tomorrow and be in the post to you on wednesday. I will confirm when they've been sent, and in the meantime I can only apologise for the setback. I am pretty pissed off myself as it looks like the cats would have been enroute to QLD at the same time someone was telling me "they'll be there by 5p" but not much I can do now.
If anyone has any problems please PM me, the situation can be confirmed by PSI if anyone is starting to worry and I am more than happy to give out my phone number if anyone wants to call.
As I said, should be out wednesday but I will will confirm.
balance payment done. Thanks Rob.
I have had issues the same with TNT before and belive every word of it :( damn dissorganised freight company.
Thanks Rob.
Better news for everyone, they're here now and ready to packaged and resent. I'll start wrapping them tonight and get them in the post tomorrow
OK so far I have sent packages for
Anfz (both cats)
Cef11e
Everyone else who's paid your cats are on the way, I just didn't have all the info I needed in the one place but they will be out by the end of today
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
