  • Replies 92
6 weeks... what's going on mate?
I sms'd Rob today - he said "Just called them AGAIN - i think i let you know they were due last week but didnt show. They should be sent out today and i should have by wednesday at the very latest". If they keep stuffing him around he's going to let us all call them and start complaining.
If he doesnt get them on Wednesday i'm going to name and shame, this is pathetic.
HTH
Kot
Hi guys, yes as adam posted after more calls I have been told the cats were sent yesterday and I should have wednesday.
Again apologies for the delays but there is nothing I can do about it. I'm dealing direct with the only australian importer of metalcats so we're in the same boat as everyone else who's after these products.
Everyone still waiting has been given my phone number please free to use it as I know I have not been on the forum alot lately. Also feel free to contact PSI if you want to confirm the situation their details are listed on the website here http://www.psiproducts.com.au/
More info, just received an email confirming despatch and have the con note number. Coming through TNT again so assuming they don't f**k up and send it back to QLD again I should be posting again on wednesday to confirm they've been received.
Can anyone who's still waiting pls PM me your address. I have a postal address for most if not all of you but if you can please confirm via PM then it's one less potential holdup.
Thanx
More news, the cats are at TNT awaiting redilvery. I wasn't home when they came yesterday so gotta get them brought out again monday (soonest possible time) with the signed card etc
I'll be able to package monday night and send out tuesday morning. I'll post on tuesday to confirm cats have been sent
Just to confirm, this is for all the flanged cats? not a new batch of cats?
Hi everyone, this is some new news since sending out all of the PM's last night.
I just had an email from the supplier saying that they now have bolt ons back from welding and are packing everything for freight. I should have them all by the end of the week, although given the problems already experienced don't hold your breath...
Anyways just another update trying to keep all informed, will copy this information to PM when I have a little more free time.
Guys, everyones cats have been posted as of today (with the exception of 3.5" bolt ons that have been discussed with the buyers).
As I have said in posts and PM's EVERYONE WHO IS STILL WAITING HAS MY PHONE NUMBER, please use it rather than posting here as I have told you time and time again I probably will not see the posts.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
