So,
I'm looking for a race suit, for two applications, circuit (track days) & go karting.
I know that I don't need a suit for track days, but I need one for go karting, so if I can get one that suits both applications that would be sweet as.
Where should I be looking?
What sort of suits are there available?
Do I need a CAMS approved suit?
Cheers
Jase
https://www.sau.com.au/forums/topic/134535-race-suits/
  • 4 weeks later...
For national you need at least 2 layer suit. Ive found my new sparco to be alot more comfortable then the old erg one i shared with my old man.
I think the stuff has got to be FIA approved.
My new sparco suit is upto FIA 2000 stds. Sparco Sprint series.
Edited by r33_racer
https://www.sau.com.au/forums/topic/134535-race-suits/#findComment-2581929
NOTE: Please take this info with a pinch of salt. It is only my experience, and not a definative guide. I take no responsibility for others use of this information.
OK, Here is the info off the top of my head.
First and foremost, there are a few different types of suits.
Single layer - One outer Layer of fire proof material
Dual Layer - Two Layers of fire proof material, One outer, one inner
Triple Layer - Three layers of fire proof material, One outer, two inner.
Single layer is suitable for club events, upto and including motorkhanas, hillclimbs, sprints.
Dual Layer is suitable for anything in the National level of motorsport - Rallys, targa's and the above mentioned stuff - Not including things like V8 supercars.
Triple Layer required for any FIA stuff and international rally's.
There are two standards that are recognised by CAMS and FIA. And that is the 1986 FIA standard and the 2000 FIA standard.
Without this approval on the neck of the suit the suit cannot be used in the events of national and state level.
Apparently the 1986 standard is being phased out, but CAMS has not yet put a due by date, so you may find that most shops are selling these suits at reduced prices.
Next, Suit Material.
There is from what I see, Wool & Nomex.
Wool is a natural fibre and as such has some different properties to that of Nomex, which is a man made material. If you want to find out what they are......google it.
As for which is better, Nomex is more expensive, looks shineier (is that a word?) and feels nice (too me) on.
Wool is less expensive by almost about a third, looks more dull and can be (but not always) itchy on the skin.
For go-karting (racing) you need an abrasive resistant suit, which is made from a polymer like nylon. These suits CANNOT be used in car racing due to the non compliance with the fireproof material requirements.
So for my case a single layer suit will be suitable since I will not be racing go karts, only mucking around in them.
so, there it is.......
A very simple guide/layman explanation of race suits how what where.
https://www.sau.com.au/forums/topic/134535-race-suits/#findComment-2588870
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
