This kit is mostly new and was going to go on my R32 GTR. Unfortunately I can't afford to keep this kit and do other mods so I have to put it up for sale :P
New External Wastegate $150
- 50mm
- 4 bolt flange
- gasket included
New custom polished high mount manifold $500
- T4 flange
- ported and polished with tuned length runners
- gaskets included
- High quality stainless steel with TIG welding
- External gate doesn't have to be used
Dump/front pipe with 4 bolt flange to suit high mount manifold $100
HKS Y intake pipe $150
New Adjustable Fuel Pressure Regulator with gauge $50
New Oil catch can $50
PM or email [email protected] for details
Thanks
Wegs
Edited by wegs
** looking to put my money into coilovers and wheels so if the right thing came along i would consider trade**
:happy:
You need to get your priorities right :D
Seriously man, I would keep and install that kit, if you don't want to do the single turbo conversion sell the T51 but keep the rest I would :sick:
Tell me about it ;) I would love the chance to fit the kit and scare the daylights out of passengers (as well as myself) but it's a bit out of reach and i'm more happy with getting some 19"s instead.
More details for parts sourced and all parts now itemised with seperate pricing (all below replacement cost). Manifold and gate don't have a brand marked on them. I have found the wastegate is a cheap option and marked price accordingly. Manifold is very well made with stainless steel and neat welds.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
