RPM Performance - Sat' 31st May Drag Day - post here if intending to enter
Sorry Matt take me off the list .... I haven't got any of my proposed mods done cos I've been too busy so there's no point running (since I ran a couple of weeks ago) .... will definitely be there though for a look!
  • Replies 111
Hey Matt :D
Can you update the first post with the following:
PAID
rob vu ss ute - Monaro CV8
BRUTE - VU SS
Remove the following
LS1-250 - VT HSV Senator
Hyper8 - VX SS
....and
HRT Stroker PAID
Jarrett - VT Senator HRT PAID (Jarrett may be above?)
are the same person.
Cheers
Mat
Yeah John (Munro) mentioned a few wks ago that Keir was going to run his car at this event. I've not heard anything more about it until now. Keir is welcome anytime as far as I'm concerned!
Matt,
I have 3 people paid up today.
Clint32 - R32 Skyline
Alexis Paul Poole Honda CRX
Rob VU SS - Monaro
Ben Siedel's RX3 RPM car.
I spoke to Mike Petrou to invite Keir Wilson with his GTR to the meet and Mike said that he will get back to me. Yeah, for sure, wouldnt mind seeing the 9.38 secs 32 on the track!!
Ivan will contact AIR today & find out about pit crew entry (in particular late arrival) takeaway food options & a few other details. He'll post the info up asap.
Keir Wilson will be running his GT-R :D
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
