Hey guys,
I started the car up this morning and it just idled roughly for a second or two and then this noise developed. It's a sort of 'knocking' noise, but im sure actual knock doesn't sound like this when revved. Sounds expensive, so i'd just like to see if anyone has ideas. I took 2 videos; one of the car idling and then in the second one i open the throttle a bit. Note the car still has good power (revs cleanly), and the fan spins cleanly (without hitting anything).
I've had suggestions including belts and bearings. Any help appreciated guys.
idling
revving
Edited by govich
https://www.sau.com.au/forums/topic/134774-engine-developed-a-weird-knocking/
I have the same sound when the engine is ideling and cold. Its not as loud as that though and goes away when the engine heats up...
I have always figured that it was a big end baring on its way out, but its been doing it for a year now with no "engine go bang action"...
Sorry to say this buddy, but u've prolly got either a)a spun big end or b)bent rod.
ill try and find the vids i took of my r33 and my gtr when they made similar noises, and ill grab the pics of what was found when the r33 was stripped down.
:) what did the re-build cost you?
I binned it and sold off most of the useful parts- manifolds, turbo's etc and bought another one from Japan that I knew was freshly rebuilt with JUN pistons-cost about 4k landed. If I had of rebuilt here instead Id say no change from 7k with desent pistons/rods. You can do it cheaper depending on piston/rod choice. The rebuilt one I have now has copped a huge caining and has not missed a beat :P
I had this sound very recently (see the link), sounds pretty much the same to me.
Was perfect one day and sounded crook at startup the next. Had never used oil before and found that it was down to half dipstick when I checked it after the sound.
El Bee
http://www.skylinesaustralia.com/forums/in...t&p=2468684
I'd have to agree with El Bee, its sounds like its in the top end a few sticky lifters maybe, try listening to it with a long screwdriver whilst the motor is idling, if it is that id be flushing it first then refill fill with clean oil and filter, also might be worth a look under the rocker cover for signs of coked up oil, just my 2 bobs worth, cheers
Good luck with it hope it isnt any more serious than that.
My initial thought was top end. All though I haven't heard an rb big end I can say it definitely doesn't sound like any big end i've heard before. Its too clacky sounding.
In fact the idling sounds exactly what my freshly built RB30 sounded like upon its initial start until the lifters pumped up. :)
Thanks guys, i can't seem to replicate the problem now, it purrs along just as before. I'll have to have a proper look around in the morning - i was in a rush to get to uni this morning so didn't really look at anything thoroughly.
It definitely isn't making any noise now though, hot or cold start.
edit: Oil level is fine, i'm thinking a lifter or two wasn't getting oil for whatever reason. I'll get more worried if it does it again..
Edited by govich
    • Like I said, "black magic" LOL In the end,  it is what it is, and hopefully, what this here knuckle head has done is an improvement and not a hindrance Not that I actually notice any negatives now, or that I will get any seat of the pants benefits when all is said and done, but best practice says I shouldn't be pulling intake air from the hot engine bay  Famous last words: I cannot see it being any worse than what it is at the moment 🤔
    • If the gases flowing in those two tracts had the same properties, you could maybe use such broscience. But the exhaust has a different composition, different normal density, different actual density (because of different normal density, and mostly because of the massively higher temperature), and different viscosity (again because of much higher temperature). Consequently, all of the fluid dynamics parameters that matter, that you calculate from these inputs, such as the Reynolds number, friction factors (for wall friction) and so on, are all incomparable.
    • And we shall have to presume that Canada is the same?
    • In the US almost everything is E10. It can't exceed 10% by much or fuel systems have trouble adapting. At the same time because MTBE, MMT, and TEL are all banned they need as much ethanol in it as possible to boost octane.
    • I was mostly jesting. In my experience (and probably only my experience) the R34 GTT physical airbox space is actually too small to flow the amount of power it wanted. By sealing the box, I made it so it could only be fed by the ducts themselves. So you can seal it up and get nice cold air which IS good, but at a certain crossover point: More Hot Air > Less Cold Air I don't think you're at this point. In my case merely ducting the hot air intake with a very focused set of ducts counteracts the fact it's in a V8 engine bay. More cold air obviously best. The solution looks great.
