Hey gang, it's here in my possesion finally.
Quick question ; headlights in the grille, how do I turn em on?
Apart from that, everything is perfect, very happy with my purchase.
picsorban!
err.... next to the headlights.. try the other switch on the stalk....
Taking a big stab in the dark here, I would say a series 2 stag?
ETA: Congrats on the purchase Matt :( Enjoy your new car :P
Bingo.
Thankyou.
it's filthy at the moment, good wash tommorow, then RWC then slap some plates on it.
I've tryed every combination of getting the grille lamps on but to no avail, so i'm guessing it's globes or fuses!
Today at work, flicking through the paperwork from Shogun, it's detailed that the grille lamps where disconnected for compliance.
Mystery solved.
On another note, how many freakin combinations of headlights do these things actually have?!
I seemingly have two sets of foggies, the headlights with there assosciated beams and the lights in the indicators which again have foglights!!
My highbeams certainly don't come out of the grille lamps.
They come of the main lights.
The only aftermarket lights I have are some yellow fog spotties that seem to be a really flush fit in the DAYZ front bar, perhaps factory option?
They are quite big.
any pics matt? would like to see that front bar if possible.
i'd be calling the compliance workshop and asking them why they disconnectred the main high beam lights as i have never heard of them having to do that?
cheers oxford
.................. general merrirment
LOL - love it... that'd be a damn funny online-gamining or forum name :P
got a few performance mods planned ?
nice car hey, good pickup. Ive got nissan spots in my S1.
pic from compliance 2 septembers' ago:
Edited by Tangles
As far as go fast mods go, just doing lowered spring and shock combo, turbo back zorst, fmic, pump and boost controller.
Might even go a highflow, everyone seems to be going on about them.
Full manual conversion, collecting the parts as we speak.
I just want some beef in the mid range and i'll be happy.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
