i got my set including bonnet sticker off ebay, unfortunately cant find the users details but if you keep checking back on ebay they should come up sooner rather than later
Do you happen to know what keywords they were listed as and in what section they were listed. Just so i can check on ebay
Cheers
PM 'AdzMax' that's his black R34 (Vic) looks shmick :)
don't know where he got it done, but he'll know the score
Yeah thanks i know, i took that pic..lol
Nah i spoke to him and am aware there is another member on the forums attempting to make them but i'm impatient :(
  • 3 weeks later...
Hey guys, I've actually just got some of these for my R34. I used a company from the UK if thats any help for you.
The company is http://www.undergroundgraphics.com
They cost in the reqion of about St£100, and you'll also need to supply them with the length of your car and also the colours you want the stripes in. They supply the graphics as three individual colours as this is the best result, but means that they are harder and more expensive to install. however the result is much better.
I'm sure however that there are Graphics Companies down there in Aus. just make sure that they have supplied the graphics before or else you'll need a very good picture of then so they can copy it.
Hope that helps.
John
How much did you pay for it? Do you have more close up side pics?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
