  • Replies 83
Hey guys,
just wondering who is goin to the jambo this year?? i am goin with a bunch of mates most likely for both days, just wondering who else is going to make an appearance for this years event.
post up if u are going and what day u will be there.
Will be there both days with a bunch of ns kiddys and some other kiddys from around the sunny coast (reprazent aighttt) i'll probly run into you down there dazz
https://www.sau.com.au/forums/topic/135191-j16-jamboree/#findComment-2514684
Ill be there all day both days, only qualifying on saturday though, highly unlikely we'll get the car to go sub 10 to qualify for the extreme class... maybe if enough of you go up too Mr Box and tell him to let me race he will?? Ill be with a pink RX-3 and Pink Datto 1600 in the pits.. come say hi :rofl:
https://www.sau.com.au/forums/topic/135191-j16-jamboree/#findComment-2515370
i wish i was going but have to work saturday and couldn't be bothered going down sunday. i got some mates going though. keep an eye out for a sigma with graphics up the side and a big pink "for sale" sticker on the back (was also at powercruise and made the final 16 in the drifting on his first time doing it). thats my mates car. it looks average (not that tidy) but goes like a bat out of hell. it has a stock sr20 in it with the usual bolt on bits (cooler, exhaust and pod). it has previously run a 12.56 (at last years jamboree, where he came second in the ET3 class)
also have another mate there in a r31 skyline. he made it to the finals last year and came second in all motor. looks like crap but again goes bloody well.
Edited by mad082
https://www.sau.com.au/forums/topic/135191-j16-jamboree/#findComment-2515571
Im competing and expecting to come last, couldnt be consistent if my life depended on it! :/
should be a good day though...will be out watching on sunday as well!
I'll be in the slowest r32 gtst out there haha its a white one - feel free to come and say hi if you see me in the pits
ryan
https://www.sau.com.au/forums/topic/135191-j16-jamboree/#findComment-2515681
yeah for sure matt. il be there.
im staying at a mates in brisbane, havin a party saturday nite down there. :P
https://www.sau.com.au/forums/topic/135191-j16-jamboree/#findComment-2516990
Can someone just tell a newbie what goes on at a 'Jamboree'?? trade stalls..drag? ..drift??? thanks very much it sounds good? :)
it is at willowbank raceway annually. it is a fast fours and rotaries drag meet with show and shine stereo comps and other entertainment runs over 2 days saturday and sunday, its the best event of the year bcoz its not just show its got everything in it.
go to these sites to check it out
http://www.jamboree.com.au
http://www.willowbank-raceway.com.au
Edited by 85URK
https://www.sau.com.au/forums/topic/135191-j16-jamboree/#findComment-2517061
that's old news, i knew ages ago :)
https://www.sau.com.au/forums/topic/135191-j16-jamboree/#findComment-2517400
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
