Guest EVL-R33
ey ive got a problem with my gears crunching as all of us do.. i changed my oil and it still crunches...
i see the thread for Redline Lightweight shockproof oil and it soudns the go
sorry if this has been answered But WHERE can i get it from in Melboune???
and how much does it cost? coz u need 2.6 ltrs for a r33
thank u
https://www.sau.com.au/forums/topic/13561-redline-oil/
we put another box in my 33 last weekend. my mate's 33 owners manual said 2.8l so we just added that amount which we filled from inside the car with the shifter out.
To me there is something just not right about the feel of it all.
Reading thru old posts it seems if you fill it the conventional way (till it starts coming out of the side bung) you will use approx 3.6l
the 2.8l figure might be a leftover from the r32 turbo manual?
https://www.sau.com.au/forums/topic/13561-redline-oil/#findComment-268203
  • 3 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
