My intercooler has developed an unhealthy brown colour after dealing with years of exhaust smoke and crap like this.
I wanted to clean it, but the fins are quite brittle so i cant really use any contact on it.
I was thinking of using alloy wheel cleaner on it. Can anyone think of any reason why I shouldnt do this? eg. damaging the intercooler or something?
Has anyone tried it before?
https://www.sau.com.au/forums/topic/135634-cleaning-intercoolers/
Hi Jon!
Might sound silly but what about degreaser? A small mixture so its not as strong?
Ive never cleaned mine either - but then again its kinda newish!
Would be interesting to find out what others do :laugh:
Aluminium sucks for this reason, it tarnishes easily and you have to take a fine layer of actual metal off to get that clean look again, there are products that we use to clean up ali after welding it, it evil stuff though as it can cause bone cancer.
Primordial, I haven't tried cleaning my intercooler yet, but using alloy wheel cleaner sounds as though it shouldn't cause any harm. When it comes time I think it'll either be using alloy wheel cleaner or degreaser and make sure it's rinsed off well.
Just have to be really careful with the fins, just like the radiator core. The only downside I can see with the liquid/spray cleaners is how to get any solids, such as bugs and dirt, out without damaging the core?
What about the inside of the intercooler? Are you going to clean the inside as well? What are others opinions/advice on doing this?
Thanks for some great ideas guys!
Tomorrow i'm gonna pull the core off and give it a clean. I'm going to start with alloy wheel cleaner, and if that doesnt work, i'll try degreaser. I'm going to use a high pressure hose to blast the residue off (from a distance obviously!).
For the inside, I've heard that a 50/50 mix of metho and turps is the go!
Ill give it a go and let you know!
I read a tech tip from hot 4's and gave it a go ....don't know issue number
something like this
I removed the core taped a plastic bag to one end of the end tank then emptied 3 cans of degreaser into the core....
then taped another plastic bag over the other end tank.....
invert back forth then empty....repeat if real dirty then wash out with water.....
i used tap water but i imagine de min wouldn't harm........
stand so excess water can drain out ....
(leave in the sun)....hope this helps.....
whilst the cores off use tweezers to straighten fins.....and remove insects....I noticed a dif when I did this as the core had been on the car since I bought it....very dirty
hope this helps.
  • 1 year later...
Hot4's had a helpful tech tip!? :rolleyes: What the?
lol
sounds good, i might give this a go!
The soarer forums recommdended doing two treatments, first with just kerosene as this will disolve alot of the oil, but as well all know kero leaves a film of crap, then flood it again with metho which removes the layer, a 50/50 mix may leave some residue.
just a tip for you all i use a product called Shellite (also known as lighter fluid in some brands).
Shellite is a product called x55 from shell and is also used as automatic transmission cleaner as it is the fastest drying solvent, it is also the carrier used in tyre shine it drys off and leaves the silicone to coat the tyres.
Shellite (x55) is also brake cleaner i have displayed this to several mechanics who were paying up to $100 for a 20 litre drum of brake cleaner and i gave them 1 litre of shellite (x55) and they said that hey thats the same, i know it is because i used to pour shellite (x55) into 20 litre drums and place brake clean stickers on them and freight them to victoria.
a 50/50 mix of shellite and mineral turps is used as wax and grease remover.
to clean out my intercooler i pour 2 litres of shellite (x55) into it place my hands over the in/ outlet and shake it up and down then pour the now very black shellite out and let it dry (drys quickly as i said it is the fastest drying solvent.
Edited by black33gtst
best thing i have seen is high concentrate truck wash
as used on everyones dirt bike i know - spray on with high concentrated water/wash mix .. let it sit, then hose off.
alot of other suggestions have been for cleaning the inside of the cooler- but if you aint already taking the cooler out, try some C16 truckwash first.
  • 3 weeks later...
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
