Hi guys,
I will be upgrading my exhaust system soon and I am thinking of using HKS dump pipe and front pipe. I have no experience in this area and hence would like to seek advice from you guys. FYI, my ride is R34-GTT Coupe. My questions are:
1. Can HKS extension kit (dump pipe) be directly bolted on to standard Turbo? HKS website said that HKS dump pipe is designed for HKS turbo. I am not sure if this will fit a standard one.
2. Can HKS extension kit (dump pipe) be directly bolted on to HKS Stainless Steel Front Pipe?
Do I have to do any modification to fit them?
Thanks very much in advance...
https://www.sau.com.au/forums/topic/135701-hks-dump-pipe-for-r34/
Hi guys,
hey
all hks dump and front pipes are for stock application unless otherwise stated (most hks turbos for example teh gt-rs, 2530,2535,2540 use the same flange pattern on the dump as the stock turbo does)
soo
1. yes
2. yes
3. nope :laugh:
hope that helps
