  • Replies 51
Posted Images
changing to billet custom cams now due to tommie not making larger ones
and am upgrading to a direct port nitrous kit instead of a single
also upgrading ignition to Pro comp with CDI boxes
once its running within 3-4 weeks i will post new hp & torque graph and will hit the track
we are also making customs arms for the IRS and bushes to help the car launch.
https://www.sau.com.au/forums/topic/135859-lnemup/page/3/#findComment-2581239
Sounded like you needed the CDI with the spark not up to all that fuel.
Keen to see the on track result from such a beast.
https://www.sau.com.au/forums/topic/135859-lnemup/page/3/#findComment-2581268
the cams that are supposed to be in it was
270 @ 10.8 lift
but the ones in there are 260 @ 10.25 lift the supplier made a stuff up and i didnt check them before i got the head done
so the head had to come off again and i have to re do the Tappet clearances AGAIN what a headache.
The new cams will be around 280 @ 12.0mm lift
but i will have to see what is good for the combination.I still working out a exact set but i will post how i go.
The CDI boxes and new coils should hold up to 40 psi from what i am told .The 707rwhp dyno was done at 30 psi with poor ignition system and rich afrs
so hopefully i can making more power without pushing the tune.If i can make 750 ill be happy and just run the car at that and then if i get bored pump more boost into it.
i weighed the car and it weighs 2890 pounds with a full tank of fuel and nitrous so its not light but its not heavy.
https://www.sau.com.au/forums/topic/135859-lnemup/page/3/#findComment-2583183
With the car around 1310kg and 700+hp at the wheels should be good for the low 9's with around the 145mph region.
Would be awesome to see a good old Rb25 doing those kinds of times... Can't wait for the results hope you sort out your CDI System. Keep us posted !!
https://www.sau.com.au/forums/topic/135859-lnemup/page/3/#findComment-2596295
