I am sure a lot of you may already know this, but for the benefit of anyone who doesn't (I didn't till yesterday):
As Skylines have batteries in the boot, they must either be a sealed battery or have an external vent out of the car. Apparently if you get a power surge the battery vents producing a highly flamable gas.
I got a new battery yesterday and the guy in the battery shop was shocked that my car had an unsealed battery and no external vent! He said it is highly illegal. I have also spoken to someone else with a skyline (eliteR33) who told me that it has become one of the things the Police are cracking down on imports.
I am fairly sure if you have a sealed battery it will say sealed on it. If in doubt I suggest you get someone who knows the difference to check it out.
The benefit, my new battery is maintainance free, so I don't have to pull it out to check the water all the time!
https://www.sau.com.au/forums/topic/13593-battery-warning/
Gday
Must be one of the minority with the battery in the back.
Funny that the NRMA guy new exactly where to go when the lights had been left on. (She did it)
As far as I know they all reside there and should be sealed for safety.
Sealed batteries don't have the screw caps for topping up (about six of them) across the top of the battery.
El Bee
https://www.sau.com.au/forums/topic/13593-battery-warning/#findComment-266935
hehe red you prolly mean every r32 you have seen
r33 got no space under the bonnet for it
there is a fuse box and a boosting point with a + and - on it, might have confused it for a battery
but r33 is in the boot. unless someone felt the need to unbalance the car and stick the battery back under the bonnet
https://www.sau.com.au/forums/topic/13593-battery-warning/#findComment-267181
Yepp. R32's have them under the bonnet, while the R33's have them in the boot cause there is just too much HP power under the bonnet :)
James, glad you told me cause I'll be in the market for a new battery soon. The one that's in mine now goes flat if I leave the radio running for more than about 30mins :)
So far I've charged it 3 times in the last 2 years cause it wouldn't start the car.....
What size/type/CA did you end up getting? I had a look at mine and I think I'll have to change the terminal connectors to larger ones if I go with a bigger battery.
And I've still got the vent pipe thingy that can connect to a unsealed battery. I suppose I'd need to get one that the pipe connects to if I go with an unsealed battery ???
J
https://www.sau.com.au/forums/topic/13593-battery-warning/#findComment-267321
hay guys this is what i was talking about ages ago my 180sx which is comming down has the battary in the boot which means the guys told me i need sealed battary in a battary box or either make a vent for it which i dont want to do? can you get sealed battarys ????> the ones which i was told that dont reluse flamable fumes are the dry sell? the odessay ones which cost like 300 buckz and weigh 50 kilo but apprently last for ages =)
is there anything else which might be cheaper =)
https://www.sau.com.au/forums/topic/13593-battery-warning/#findComment-267609
I fitted an Odyssey battery to my R33 for the leakage reason (no fluid, totally sealed), plus they are light and have excellent cranking current.
They arent the cheapest though, and you can get 'sealed' batteries that use paste rather than fluid and have a safety vent for excess gas much cheaper - call your local battery specialist and ask about paste based sealed batteries for inside cars.
https://www.sau.com.au/forums/topic/13593-battery-warning/#findComment-267627
I got a 100% sealed battery, maintainance free, which cost me $130.
Jay, I'll check size etc. for you. I just went to the battery factory in Fyshwick and they changed the terminal connectors to larger ones for me. I needed a new battery because after 5 mins of stereo the car wouldn't start!
https://www.sau.com.au/forums/topic/13593-battery-warning/#findComment-268095
Cool - that's not such a bad price.
Yeah, mine is crap too. The thing in my car is only about a hand span across !! Damn small... :P
Cheers
J
https://www.sau.com.au/forums/topic/13593-battery-warning/#findComment-268110
The factory R33 battery is a POS! It's rated @ 270CCA - that's pretty average for a modern fuel injected car with all the mod cons.
I started by replacing my stock battery with an Odyssey ES12V800 (~$300) 400CCA (800A start pulse) boot mounted battery isolator & new quality cabling.
The Odyssey died in less than 6mths! Yep my Odyssey dropped a cell in 5 or so mths. I tested it, 2 battery specialists tested it & then finally an Odyssey rep came down from Sydney (as he believed it was me that had caused its failure) I asked him to explain just how I had caused its failure? I even offered to allow him to go over my cars elec'/charging system, my battery isolator s/w & cabling, even run tests for alternator charging voltage, reg serviceability etc. The end result? The Odyssey rep didn’t even have the decency to apologise to me when it was proven to be a dud battery! I got my money back. Stuffed if I wanted another Odyssey if that’s how they treat an honest customer!
I did nothing more than buy & fit the Odyssey battery. It was installed correctly & was never called upon to do anything more than is claimed it can (deep cycle etc.) I work in the aviation electrical field so I know a bit about batteries.
I’ve had an Optima Yellow Top fitted for mths now. Bloody awesome battery! Rated @ 650CCA. Deep cycle, the works! The starter motor doesn’t know what’s hit it when you crank the engine! It’s certainly not cheap ($400+) It’s big (only just fitted in the battery tray – with a bit of massaging) but it lives up to the claims of it manufacturer (unlike the Odyssey).
My 2c
https://www.sau.com.au/forums/topic/13593-battery-warning/#findComment-268421
whatsisname: Yeah I want to get an Optima next time round. I have heard a lot of good things about them! Just need the $$$ to spend on a battery!
Jay: The battery I got is an "AcDelco Sealed Maintenance Free" (430CCA, 45AH, 80RC)
https://www.sau.com.au/forums/topic/13593-battery-warning/#findComment-269196
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
