Hi all
Found 2 types of pads I am interested in. Have spoken to many people and they all recommend the Endless SSS pads.
However I also stumbled across the SSM series pads which are slightly more expensive. From what I can tell they are very similar pads except that the SSM have very low dust. Supposedly the SSS have low dust as well, but if there is a SSM, then maybe it is not so low after all.
I am looking for anybody's experience with the SSS or SSM and their dust levels and braking performance.
Specs are:
Super Street S Sports
Temperature Range: 0 ~ 500oC
Average Coefficient of Friction: 0.35 ~ 0.43
Super Street M Sports
Temperature Range: 0 ~ 530oC
Average Coefficient of Friction: 0.30 ~ 0.40
Anybody know what the difference in friction coefficient will translate to on the street in terms of braking?
I am looking for pads for the street, with low low dust, not noisy and a good initial bite that does not fade off overly quickly.
I know compromises will have to be made because you cant have it all. My current pads (Formula Ferodo) are great, but just too dusty.
Thanks
https://www.sau.com.au/forums/topic/135938-endless-sss-or-ssm-pads/
well i would say with a lower CoF the SSM will be less effective, not by much, but definately a little less effective. They both have quite wide ranges of both CoF and operating temp. so they will both be good on street, but not so good on track. i've used the SSS and they were good on street. very quiet (no squeal at all, ever) and not too dusty (nothing like bendix ults etc). quite a soft pad too so they wont chew out a rotor when cold.
How dusty is not too dusty BB? My wheels get a tinge of brown dust with my current pads after one day in the city. A week after, they are pretty much fully brown haha! Quite annoying.
Also how were they on the initial bite? ie. did they wipe off alot of speed quickly?
Finally, my current pads have a average coefficient of 0.43, how will the Endless pads compare then? less effective I guess?
Edited by nuffsaid
well it's not just about a raw CoF number. you need to consider the range, and the temperature that it can operate effeciently in.
i really dont know how to quantify dustiness other than to say i didn't think they were too dusty. for example i currently use endless CC-R for track work and they are crazy dusty, and LOUD and dont stop at all when cold.
the endless SSS are a fairly good pad for street/spirited street driving.
Argh I guess coefficients are hard to make a decision by because they operate at different temps like you said.
Best thing to go on is experience then.
BB: in comparison to say Bendix Ultimates how dusty are the SSS? I think the Ultimates are almost on par with the current pads I have in terms of dustiness, except its more of a fine brown than black dust.
Okay just found out my current Formula Ferodos are 0.46 coeffecient with temp range from 0 to 650 celsius. I am guessing the endless pads wont be as good then.
Although because they are cooler pads, they would probably have a nicer initial bite, and hopefully less dust than the Ferodos
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
