They're big, cheap, and American.
Having said that I have been tempted to try them - they make 11ty-billion different types of calipers!
As long as the design is OK(ie are stiff enough across the bridge, take a large diameter rotor / thick rotor etc), they should work fine...
Give it a shot and let us know how you go!
If you need some radial mounts machined I might be able to put you on to someone
cheers
https://www.sau.com.au/forums/topic/136224-wilwood/#findComment-2533227
haha I can be the guinea pig!! :O
I'm very tempted at the moment... Basically I've found a full kit that uses the superlite 4 piston caliper, a two piece 330mm rotor, braided lines, pads, bias valve, brackets etc for not much money... basically a little bit more than it would cost me to buy caliper extension brackets, rebuild my existing 32 4 pots, and getting some DBA 5000's, so yes, very tempting...
https://www.sau.com.au/forums/topic/136224-wilwood/#findComment-2533523
As Ronin said, Wilowood make a caliper for every man and his dog. So jsut check the model of caliper and make sure the pistons arent smaller then what you are running at the moment.
Im with you, i often look at the Wilwood gear and what they can be bought for. They have calipers that go for $5000 each, but they also have good 4 pot and 6 pot calipers that are between $600-800 each so is tempting :laugh:
https://www.sau.com.au/forums/topic/136224-wilwood/#findComment-2533907
wilwood have a good selection of pads available,
its just a matter of getting the right one.
we started using a harsh compound and new rda slotted rotors
would only just last a rally. now use a softer compound
and get 2 rallies out of rotors with similar stopping power
and not so touchy
https://www.sau.com.au/forums/topic/136224-wilwood/#findComment-2535418
Thanks for the feedback guys.
Dougmo, which compound do you use, and are they readily available here??
The caliper that comes with the kit is the Superlite 4, so I'll have a look into the piston size. I wouldn't mind going the Superlite 6, but it's probably a bit overkill, and I'm going to have trouble getting them inside a 17 inch rim...
https://www.sau.com.au/forums/topic/136224-wilwood/#findComment-2535530
Yeah, seen those mate, that's where I got my pad choice from :huh:
Thanks though.
no probs.
btw, you shouldn't have a problem fitting the 6-piston calipers in a 17" wheel as Wilwood have a brake kit for the sierra cossie with 6-piston calipers, 323mm rotors and they fit inside 17's.
https://www.sau.com.au/forums/topic/136224-wilwood/#findComment-2546041
Really?? Cool, I'll have a look into it, and see what they say.
Cheers man.
Btw, this is the kit I'm looking at, optioned with Polymatrix E's and Slotted, Zinc coated rotors
http://wilwood.com/BrakeKits/Pages/04/index.asp
https://www.sau.com.au/forums/topic/136224-wilwood/#findComment-2548401
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
