  • Replies 78
If I can get a 13.999999 I'd be stoked! I'll probably get low 14's though.
The GT Starlet should get pretty close to flat 13's though :happy: What about yourself? DO you know what time to expect? Send me a message when your down there if you want, i only work about 2 minutes away, I can hear the cars on trackdays from out the back of work!
https://www.sau.com.au/forums/topic/136227-wsid/page/3/#findComment-2552895
blew a f**king cooler pipe ;)
Been there, done that, know the feeling - better luck next time mate :mad:
On a brighter note, I managed to nail another 11 which was the aim of the night for me - 11.996 @ 115.50mph.
I'm a bit miffed about my mph though. It was consistently down around 115-116mph all night, whereas I was up around 118mph last time out :laugh:
Saw quite a few lines out there as well - fairly good night overall.
https://www.sau.com.au/forums/topic/136227-wsid/page/3/#findComment-2555115
next week and the week after and the week after!
car is in mechanics now.
got it back on but too scared to run again,
congrats on the time mitch for your first time out!
Craig - awesome - 13.6@102 :happy:
https://www.sau.com.au/forums/topic/136227-wsid/page/3/#findComment-2555731
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
