  • Replies 176
Posted Images
are you serious huddy........hit one like i did and then complain, you got off so lightly, your very lucky to have minimal damage and the parts already there for replacing.
think of it as a reason to spray your flared fenders and finally put them on
dont even sweat it mate
yeh i am.......lol, i drive like i dance ive got 2 left feet
think about it......it really explains alot
by the way ive got some 17/40/215 semi's here if u want em, bridgestone potenza re55's 80+ percent tread no flat spots........only want like 200 for the pair, let me know or if u know anyone who wants em
Edited by Nathan_G1
well... hit the wall at Mallala last weekend... basically front left onto grass and understeered and couldnt get it back... Front of car into tyre wall. Minimal damage considering f**ked up in top of third gear. damage was - crack paint on passenger guard, passenger indicator dead, front bar inihilated, front indicator destroyed or gone and a split intercooler silicon hose. Wheel alignment tomorrow but i think it should be A OK!
Want to thank KANSAI AUTOMOTIVE / VIVA GARAGE for helping me get everything sorted so quickly! Also ADELAIDE RADIAL TYRE for getting everything under the car in perfect working order. Cant recommend these business' enough!
KANSAI AUTOMOTIVE - www.kansaiautomotive.com - import cars/bikes/parts/turbo kits/suspension/performance and MORE!
VIVA GARAGE - www.vivagarage.com.au - AWESOME bodykits and excellent service. David and Henry are always more than happy to help out
ADELAIDE RADIAL TYRE - www.adelaideradialtyre.com - DRIFT SPECIALISTS for WHEEL ALIGNMENTS! at affordable prices!!! custom drift fabrication on request, tyres, mags, etc... Matt and Darryl will always find time to fit you in!
Cant thank these guys enough, i'm now almost ready again for SD next weekend!
Here's some pics i took today.
post-9092-1175867298.jpg post-9092-1175867270.jpg post-9092-1175867260.jpg post-9092-1175867251.jpg post-9092-1175867241.jpg post-9092-1175867228.jpg post-9092-1175867217.jpg post-9092-1175867207.jpg post-9092-1175867193.jpg post-9092-1175867288.jpg post-9092-1175867280.jpg post-9092-1175867181.jpg post-9092-1175867170.jpg post-9092-1175867158.jpg
I'll get some better pics soon - the rear bar still needs to be wet rubbed and buffed, gurads have been wet rubbed, but need buff still, and the new (replacement) front bar needs wet rub and buff... :sick:
Edited by huddy
cracked bonnet / smashed indicator / bent guard / cut silicon cooler pipe hose / front bar in a gizzilion pieces / front indicators gone / alignment out, fingers crossed nothing bent.
no pics of the damage sorry - just afterwards.
wet rubbed, polished and buffed front bar today (well tried ROFL!!!) came up... not too bad, just glad i got stickers on it lol.
hey hudster looking gud now :P
question:
was ur a31 boot lid damaged? if not u selling?
how much does da carbon fibre bonnet and boot weigh? :(
oh and next time u talk 2 ur viva garage tell them there website has too many bugs...
da links dont work.. code showing up in the view field
Edited by Dan_J
  • 3 weeks later...
here's a dyno sheet of the new setup - just changed to hks gt 2540
tuned by SIMON at MORPOWA auto and dyno!!!
end result is 240rwkw at Morpowa's dyno. (known to read a LOT lower than some others around!)
top of the graph is suspected wheel spin. even with 80L of water, strapped down and 2 guys sitting in the boot.
We are now suspecting that the engine is in fact a low compression engine, and as it was built in japan, really go nfi if it is or not. So just guessing it is because of the boost that is needed. Tune is very safe still with AFR's in the 11.5 - 11.2's on pump fuel.
I'm happy, and yet to test drive it!
Should be fun!!!
Edited by huddy
bugger all more than the 2530, i haven't driven it on high boost yet. low boost ( 1bar) feels about the same as it did before
also now fitted
Power Steering Cooler
Triple flash strobes hehe
spacers rear 25mm
rear guards pumped and flared roughly 25-30mm ***LOOKS PHAT***
re-painted guards, now colour matched (well better matched lol)
got 9pairs of tyres to kill this weekend :banana:
also now fitted
spacers rear 25mm
got 9pairs of tyres to kill this weekend :bunny:
pics? :banana:
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
