I know i could have searched this, but i wouldnt get an answer to my question directly, more so i would have to read through pages and pages of unrelated information.
Anyway, I was wondering what pads people are using and what they think of them.
1. In terms of overall performance (stopping ability, fade, etc.)
2. In terms of brake dust
3. In terms of noise
Any help is much appreciated
Cheers, David
https://www.sau.com.au/forums/topic/136405-brake-pads/
Do not use Bendix Ultimates if:
U dont want ur brakepad to literally sh$t dust
U dont want to wake eveybody up in the street and the next street over, especially when slowing down from normal driving speed.
Brake fade is good BUT mine starts after a spirited drive, not fade but less bite, but it could be bad rubber.
Endless all the way
BTW BNR32 with new RDA slotted rotors and Bendix Ultimates :)
https://www.sau.com.au/forums/topic/136405-brake-pads/#findComment-2562644
I have an R34 and with Ultimates I have belted around the track lap after lap and never got any fade. They are dusty as hell though, prone to squealing and eat rotors for dinner. They wear out fairly quickly but for a performance oriented pad they are cheap. They do stop well though.
I just put some Ferodo DS2500's in last week and went to a track day on sunday. I'm told they last twice as long as Ultimates but yet to find that out. They give a firmer pedal. They stop well but have to push harder. They didn't fade. No noticeable dust after one track day. Only squealed when really hot.
Apparently my rotors were glowing red yesterday after 220 down to 170km/h stab and then 190 down to 70km/h stop straight after.
https://www.sau.com.au/forums/topic/136405-brake-pads/#findComment-2566835
What is the difference between DS2500s and DS3000s? Anyone know? Price difference?
3000s are only meant for race use, apparently they will destroy your rotors when they are not hot.
2500s are fine for normal use as well as hard track use, and even come oem on some hi performance new cars.
https://www.sau.com.au/forums/topic/136405-brake-pads/#findComment-2576574
I was using DS2500s for a while.
I didn't notice any degradation in performance when cold, and it took a fair amount of effort for me to fade them (even on my underbraked car). The only thing is they cover your rims in dust if you even look at your brake pedal. And they squeal when cold.
I'm on OEM pads since I did a brake upgrade and got pads with the calipers, but as soon as these pads die I'll be going back to the Ferodos. Dust or not, they work.
https://www.sau.com.au/forums/topic/136405-brake-pads/#findComment-2578552
The DS2500s are a "sprint" pad. They require almost no heat to come into operating temperature so they work from the get-go, and they can handle a reasonable amount of abuse. My mate's Formula Ford ran DS2500s in the NSW State Championship, where each race is around a dozen laps, or about 15 mins. No fade. They're not heavy cars, but the rims are tiny which means the brakes are tiny, and they work their brakes harder than most of us ever do.
The DS3000s are an "endurance" pad. They need more temperature to come on (they are noticably weak when cold), but they'll handle more heat and I believe last longer. If your race isn't won or lost based on your ability to stop in the first 2-3 corners because all the racers know there's plenty of time later, its a better pad.
https://www.sau.com.au/forums/topic/136405-brake-pads/#findComment-2578566
I currently use Delphi(AP) Lockheed Type ZR(50-850degreesC) brake pads on my GTR32 and i run the sprint,clubman and national circuits on Queensland Raceway, they bite well and get up to temp fast, didn't experience brake fade with them. Initially when bedding in i had quite a bit of squeal with them, after 1 track session they don't squeal at all, i don't see too much brakedust with them too. The endless CC-X (50-700degreesC) pads are pretty good as well...
https://www.sau.com.au/forums/topic/136405-brake-pads/#findComment-2578699
winmax the best pads ive had driven in or heard of(apart from da brembos in evo 8mr) fair bit of dust good for everyday driving. took car for a rap down the royal wid lots of hard braking didnt fail or fade once no noise and ive had them on car for bout a year wid ten thousand kms and only bout half done 0-500 operating temp good stopping power all the way through the temps but tink you can only get them through bel garage not the cheapest at $ 220 for the fronts and $180 for the backs im very happy wid em
https://www.sau.com.au/forums/topic/136405-brake-pads/#findComment-2582138
Um, after doing ALOT of research, the way the Bendix Ultimates are made (And the whole Bendix range) they shouldn't be run with slotted rotors at all as the slots will just tear them apart.
That's interesting to hear. What would be the best pad to run with slotted rotors then?
https://www.sau.com.au/forums/topic/136405-brake-pads/#findComment-2583211
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
