Wanting to put in an intercooler on a RB25DET. Does anyone have any advice?
1) are the r33 gtr and gts-t intercoolers directly interchangable without changing the mounts or piping?
2) is it posible for the RB25DET to make that crazy noise the RB20s in the VLs make? If so, what needs to be done to the engine for it to do this?
Any other general comments are appreciated.
-Enyoy
https://www.sau.com.au/forums/topic/136943-coolers/
The factory GTR intercooler is a great peice of gear, with proven flow ability but for the money, you would be better served buying a complete off the shelf kit from the likes of Just Jap as the GTR cooler will require custom piping and brackets etc.
https://www.sau.com.au/forums/topic/136943-coolers/#findComment-2544853
A cheaper option is putting an R34 GT-T cooler in. It's a side-mount like the R33 is, but the R34 cooler is thicker and flows a bit better.
If you're only chasing modest power gains I'd do this, otherwise go a front mount kit.
https://www.sau.com.au/forums/topic/136943-coolers/#findComment-2545064
why would you bother putting a gtr cooler on when you can get new coolers for $150 and cooler and piping kit for $400. and i think you should do a bit of a search first there are many many topics on coolers. also dont block off your bov for that "sik flutter noise" makes you look like a wanker, and isnt healthy for the turbo.
https://www.sau.com.au/forums/topic/136943-coolers/#findComment-2545095
this would be pretty much a waste of time and money especialy if you live in a hot part of aus.
the reason you would buy a GTR cooler and get custom pipeing is because of flow and cooling efeciancy. cheap kits are cheap kits. they dont flow, boost will drop and cooling is average.
also the cheap kits fit pretty average and most of the time the front bar has to be hacked to fit it where as GTR ones are made to fit.
https://www.sau.com.au/forums/topic/136943-coolers/#findComment-2546053
GTR coolers are mass produced and have pretty poor flow capabilitys, the fins are very close together. also the $600 for a gtr cooler and then bout $400-$500 to get piping made up is goin to be better than say $350 kit from CRD in sponsors section. For most people unless your chasing like 1000hp or something stupid the cheap kits are fine, also the cheap kits have been tested compared to expensive ones and there is like 2% difference. For me $350 compared to over $1000 to not cut the front bar and have like maybe 2% flow difference just isnt worth it and most people will agree with that.
https://www.sau.com.au/forums/topic/136943-coolers/#findComment-2546074
Is that the kit that requires to chop the battery tray or does it run the pipes through the existing pipes?
Cheers
Josh
I personally dont know what to do to mine at the moment as I have I think to take the battery and get a smaller one but maybe ill run the pipes to the exsisting one... anyone have better ideas?
https://www.sau.com.au/forums/topic/136943-coolers/#findComment-2546266
actually,the r34 gtt sidemount is good for 200 odd rwkw/awkw and wont heatsoak too badly if you are using a stock/factory option front bar which is designed to flow in that direction. using the factory shroud will also help.
i think for ~$200 and DIY install (easy as piss), the r34 gtt cooler upgrade on an r33 is a great idea. this is what i have done second time around on my stagea, first time being a GT-AH cooler/custom piping :wave:
https://www.sau.com.au/forums/topic/136943-coolers/#findComment-2546418
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
