Guys and gals,
Dinner will be at.......
Naremburn Pizzeria
300 Willoughby Rd Naremburn 2065
(02) 9436 2059
Starting at 730pm
The beer baron says there's a bottle shop next door, so keep that in mind
Please post up like usual, ill ring a few days before so please let me know for seating arrangements
Who's in?
N1GTR
N1 R33 GTR (Both Jess and Sexylegs)
D_I_F
Miss Turbo
A31Deviat or sumsing
Beer Baroness *maybe*
Slide
Tragic
d00dz if he gets a lift
Blitz as always
Smoky
lingeringsoul (needs a lift - 200meters out of the way guys :huh: )
4DoorGTR
Liz
damuscat
mr 32
Bro'Duh
Haysey
dead32
OnGsTa
Amy33
T04GTR
For the directionally challenged :P - use this link for directions LINKY
https://www.sau.com.au/forums/topic/137285-sau-monthly-dinner-all-welcome/
  • Replies 89
cool cool, but what I meant was why create 2 in the first place? :ninja:
Well i was going to do a poll in the other one, but it appeared a desicion was all agreed upon so to make things clear for people that may not be regulars at them, or even first timers i locked the other one and made this one, which is nice and clean (and not confusing) so if anyone wants to come along they should feel free to as its not an exclusive event - thats all. Delete it if you want
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
