Hi
Its almost impossible to do this
The cost is in the millions
Im currently talking to a few key people about having a combined day up there
To be honest, it doesnt look very promising which is a shame
that a shame always wanted to do the mountain without do the speed limit
remember those days you could go around and there was no cops,now they wrer good
they still have track days up there,cant hire the track because people live up the top of the mountian and there driveways exit onto the track.
just join the bathurst lite car car club
got a couple mates in it so Im looking into it.
no need :) SAU NSW are invited to all their events.
The next main track day at bathurst is the first weekend in december, I am getting a copy of the entry form and supp regs when they are ready,
no need :ban: SAU NSW are invited to all their events.
mmmm that would be sooo good!
too many walls!
now that you mension it :wave:
Duncan - good good!
great news!
Just wondering though if you can just do a saturday session with the club?
(I work sundays :mellow: )
and make sure those forms are up! hahaha
I dont want to miss out on it !!
:D
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
