Hey guys.. I got an r32 skyline,
Noticed yesterday car wasnt very as powerful as it has been (in the last couple of weeks). Im pretty sure I have a boost leak somewhere but im just after the stock boost level of a r32 gtst. On the stock gauge it reads about 5 and then dips down to 4.5 or 4psi.. im dead set it usually runs about 7.5
Anyone with any ideas please let me know.
Michael
https://www.sau.com.au/forums/topic/137726-stock-r32-boost-levels/
dont go too much boost, turbo will chuck a hissy fit lol :)
Mine was fine on 16psi for quite some time. Still is fine now; it has a little to do with luck of the draw, and how well the motor has been tuned with regards to NO detonation, mixtures are not lean and most importantly how hard its driven.
Yeah its strange how some people say its crazy to boost a R32 turbo over 12 psi but I know of one guy whose been running his stock turbo on 18psi since he imported the car 5 years ago and it hasnt missed a beat once!
slightly off topic, i've been running my 33 at 14psi on the stock turbo for a few months now. haven't had any issues. people say they lose power after 12psi due to the turbo being out of its efficiency range, but 14psi feels faster than 12. i put it down to about 11psi for a few weeks, and it just felt dead.
Yeah I know what you mean my car made 166 RWKW on 14 PSI but Unigroup put it up to 18 to see how much more power it would make and it made close to 180 RWKW. (stock turbo)
I think what people mean is top end peak power doesn't increase much past 12psi.
The gains to be had by upping boost are through the mid range which essentially accelerates you quicker to the peak power. So.. the car feels quicker. :wave:
if i only fang it up through the gears at high rpm it feels great. i think the problem is that so many people hear that it is bad to run them at high boost that they never do, then just tell everyone that they don't go any better without ever trying it themselves.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
