gday
just wanting to know if R32 GTR front guards are a direct bolt on to the R32 GTS4?
also do i need to get GTR headlights or indicators to make it fit or will the GTS4 lights fit?
i have tried searching this but couldnt find anything...
thanks
chris
https://www.sau.com.au/forums/topic/137800-gtr-front-guards-on-a-gts4/
  • 4 years later...
thread mine (I'm looking for something and found this.) though it needed answering.
guards are a bolt on though you also need the indicators and inner plastic guards as well. no point doing the front without doing the rear as well. the car looks out of proportion otherwise.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
