ok sorry but i have to
Wikipedia - "A naturally-aspirated engine or normally-aspirated engine (or "NA" - aspiration meaning breathing) refers to an internal combustion engine (normally petrol or diesel powered) that is neither turbocharged nor supercharged."
http://en.wikipedia.org/wiki/Naturally-aspirated_engine
Enjoy the drive - "An engine that does not feature forced induction. In a naturally aspirated engine, air flows into the combustion chambers at a rate that is equal to or less than atmospheric pressure (usually less than atmospheric pressure, due to restrictions in the intake tract)."
http://www.enjoythedrive.com/glossary/parse.asp?id=8420
Smart Plugs - "* Artificially Aspirated: supercharged, turbo charged "
Bioethics website - "Need all nations agree on this definition? Or is it not more likely that some cultures will accept cortical death while others will demand brain-stem death and yet others will insist that a patient is still alive so long as his heart is beating, even though his entire brain is gone and he is artificially aspirated,"
**So being on a respirator is articially aspirated apparently
http://www2.unescobkk.org/eubios/bfp/BFPFL.htm
These are just too name a few... Please go ahead argue with the world- Mate you are wrong admit defeat. There is no matter of opinion fact is fact..
  • Replies 50
what the hell have i done!!!!!!
while i enjoyed reading the said view points im leaning towards not bottling just yet so any ideas that are cost effective and work.
3L bottom end yes is very interesting i even went as far as buying one and getting it ready to put in. i ended up keeping the 25 because after see her evolve im a bit in love with her. and by all reports the 3L bottom ends just don't rev as hard as the 25 ends.
so does this mean that without opening her up i've done as much as i can.
Just to add to this whole NA shitfight......
NA engines draw in their intake air under their own steam.... usually it's "Natural Air"
Turbo/Suprcharged engines have a similar "Natural" charge of intake air..... just more of it at once.
Hence if there is more air in there...... there is also more oxygen = more power (tuned correctly of course)
Nitroused engines usually draw their intake charge into the engine "Naturally".... ie. without assistance from any blower of any sort, so the amount of air/gases is the same as a "Naturally Aspirated" engine
The difference that makes an nossed engine not NA.... is that the intake charge it has drawn into the motor is anything but "Natural"...... it has been manipulated to contain more oxygen, and therefore is not "Natural"
So for my money..... nossed engines may indeed draw in their air "Naturally"...... but that's not all of it. They're not drawing in natural air, so they're not naturally aspirated.
nitrous or N2O doesn't replace the fuel, it replaces the air
as in its a richer source of oxygen
(or at least i thought so)
so in that case, you are getting more oxygen from a bottle in the car, making the oxygen delivery to the combustion process "unnatural"
for those interested i just bought a set of 440's to go into the silva just have to get them cleaned and flowed and in they go. they off to get the shit tuned out of it then to willow bank to see what sort of quater she can do.
tuning is still going to take a while so for anyone out there with any ideas of what else to do please keep them coming.
didn't want to under do the injectors nothing worse than running out of fuel. went to 440's from the word go so that i don't have to upgrade for a while.
i went the wolf because thats what was recommended to me. spoke to a few people and they all seemed to rate them. took a while to get right but once it was i couldn't be happier it really pulls hard now.
damn that hand controller is ugly though. keep it in the glove box!!
3 litre bottom end is where it's at.... sacrifice 1000rpm for lots of torque, more lower in the revs too.
What compression you at?? Shave the head a little??
thats it, the rev's you lose wont matter, as you may lose the ability to rev that extra 1000rpm or whatever, but the power you would make that 1000rpm later, you will be making more of it with more than 1000rpm lower...
besides... get it all balenced and set up properly, sacrifice the $$$ and get the RB30 block to rev just as high and make HEAPS more power :laugh:.
LMAO @ the nitrous debate! :P
A few people touched on the correct understanding of the product.
Slip introduced the very helpful concept of 'supercharging'. Supercharging as we commonly know it has 3 sub classes: 1) The old school GM 6/71 blower and its huge varitey of spinoffs, 2) the turbocharger, and 3)nitrous oxide. Of these, the blower and turbo are both forced induction (FI), while nitrous oxide is chemical supercharging.
All 3 forms of supercharging have one and only one purpose in mind... Give the engine more oxygen. The more oxygen an engine can take into the cylinder each intake cycle the more fuel can (and must) be added to burn with it.
The turbo and blower compress normal air with an oxygen content of 21% by 1, 2 or even more times its original volume and stuff it into the cylinder allowing you to use your chosen method (EFI/carbies/?) of introducing a matching ratio of fuel.
Nitrous of around 33% oxygen, being stored under pressure as a liquid, changes rapidly back to gas once introduced to the intake tract. This action chills the rest of the intake charge also, hence making it far more dense than before, hence even more room for more air and nitrous exists! Once again simply add the correct amount of fuel to burn with all that extra oxygen!
:laugh:
Il be keeping an eye on this thread as I cant wait to se what you run down the quarter with this car and also id be very interested to know what you end up getting at the wheels when you got it all tuned up and going how you want it to..
For an NA Silvia i must say that in my opinion 170rwhp is quite impressive!! Id be happy with that in my r32 GTS thats for sure..good stuff
BTW, it always seems that at the start all interesting and good NA power up posts get hijacked by all the NOS crap... Not everyone wants that sort of power,its good for pure drag cars and for bragging rights and thats about it in my view. I personally prefer a car thats quick in any situation on the road and on the strip.. thats my 2cents anyway..
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
