Just one of those questions I'm 99% sure I'm not going to get an answer for but I'll try.
I am looking at putting an Autronic SM4 into the R34 but I'm not sure if I'm going to lose the MFD display if I don't run a pnp ECU in tandem with it. Does anyone know if the R34 MFD runs through the ECU or does it get it's data directly from the sources?
Cheers.
Snowy.
https://www.sau.com.au/forums/topic/137996-r34-gtr-mfdecu-question/
I think you need to retain a pnp ecu anyway for the attesa system to operate properly... or at least this was the case for the gtr's (including r34) with motec m800's in them I have seen, and this was the reason provided.
im pretty sure the attessa is stand alone as well and doesnt need the stock ecu. leewahs car had autronic and no issues with attessa (that i know of). also seen GTS4s using normal R33 GTST powerfcs which arent "designed" for an attessa system and it works fine. On the cars loom there will be wire splicing by factory for things like TPS, RPM, SPEED etc in the wiring so the ecu won't know its there. The ALSD on the GTST is the same, it just copies the TPS wires (and others presumably)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
