Hi ppls,
my R34 GT-T had its first dyno last week. Im pretty happy my tuner managed to squeeze 194rwkw out of it at 14psi on the std turbo, virtually on the limit. I think he managed to do it coz the engine n turbo is in good knick. Wot do u guys think from the dyno graphs? A/F ratios still safe? Knocks were between 13-20 during the tune i was told, i only give it a squirt now n again, its not a track car as yet, i noticed that knocks were around 15 usually.
Mods - Power FC & boost controller, turbobak with split, FMIC, pod, BOV, plugs gapped at 0.7.
Any comments welcome.
Cheers.
R34_dyno_AFR.pdf
R34_dyno_Boost.pdf
https://www.sau.com.au/forums/topic/138152-my-34s-first-dyno/
at 14 psi, well not sure why but i have an R33 with 73k on the odo, with same mods and i managed 187rwKw at 10.2 psi.
Seams low, but the stock turbo is only good for 12 psi, after that it just pushes more hot air in, as it is ineficient.
My map however looks more like this.
Well done.
Is it just my eyes or is that a VERY rough power curve? Why is it all over the place, especially with a PFC installed? Even stock ECU power curves look more "even" than that.
Won't comment on the power figure, it's believable.
have you ever tested this, or are just saying it because everyone else does? i have the stock r33 turbo running at 14psi, and it is noticably better than 12psi, which i used to run it at. i'm putting it on a dyno in a few weeks time so i'll be able to do before and after runs.
Yes i have, well i have looked at the stock Turbo maps, the turbo will definatly go better at 14 psi, it still flows more air, but it drops almost 36% in efficiency. So you are getting hotter air at 14 psi with lower efficiency, meaning that the turbo has to work harder, hence shortining the life span.
the gain form 12 to 14 psi will be marginal unless you have a very good intercooler.
Having said all that, i don't think anyone has done any dyno runs so this would be great. see what you get.
Forget the whole hot air thing. 12-12.5 psi on the street I think is safe. The fact is that if you run 14psi all the time you will have to be very lucky for the turbo to live long.
Just because your grandma smoked a pack a day and lived to 90 doesn't mean that millions didn't die of lung cancer. No one gives a f**k about the odd one that survives. We just say congratulations, you are rare.
Power is good.
I think the curve is rough because they are both single runs. Dyno operators often print an average run which smooths it out. Also, when you have under 200rwkw you have a higher reolution on the page compared to someone with another 50-100-200 more.
It seems looking at the power flattening and even dipping late in the rev range on the high boost setting that you have a restriction in either the intake or exhaust or both. This is confirmed by the boost dropping off. Are you still running the stock cat? I guess it could also be a crap boost controller. The stock actuator should have no problems holding that amount of boost.
I know what you mean any more than about 11psi in mine and I seem to loose top end, mid range increases but I defently loose top end.
10-12 psi max for dayly driving if you plan a mountain run or a track day 10psi is the max id go.
My R33 made 195.6rwkw at 10psi, dyno dynamatics, shootout mode at ICE performance. Similar mods but I have SAFC instead of power FC
cheers
I'd be asking for a refund on the tune... its pretty average mate.
Certainly needs a bit of work.
The power curve should be smooth, and this would reflect smooth power delivery... you graph is all over the place.
And back it off to 12psi, otherwise you risk it dying.
Some do, some dont... so its your own gamble :ninja:
Some do, some dont... so its your own gamble :laugh:
i agree with what r31nismoid said.
OMG WE ACTUALLY AGREE...yay now im going to the pub to get trashed....
cheers.
i agree. Your power curve is very erratic. The curve is what you'd expect from a std ecu. not a pfc. Put the boost down a little, an if the pfc is tuned properly then you will get more power, and more importantly a smooth power curve, hence a smoother and better power delivery which you will notice on the road.
Also i feel it is too rich at 11.2:1. Try and get it closer to 12:1.
Power is good.
Could my power curve be rough becoz they r individual runs like Abo Bob mentioned? Are those smooth graphs u guys posted a average power run? Just wondering?? Abo Bob - im running BATMBL's 5" body cat so i wouldn't have thought that it was a restriction, also have BATMBL's split dump & a Blitz NUR catback so i would have thought there should be minimal restrictions there. Boost Ctrl is the Apexi Power FC EBC, wouldn't have thought that was crap either. I can't think of wot else could be restricting it :laugh:
Also does anyone have any idea wot the lower graph with Lb on the right vertical axis reads? I thought it was torque at first but after converting Ft Lb(assuming thats wot it is) to Nm, it cant be torque.
R34_dyno_Boost.pdf
Well, you have to take into account that the stock turbo is running out of puff.
it wont hold much more than 12 psi up top when tuned as it simply isn't big enough too.
Torque can be either in foot/pounds or kilograms/centimeter.
Mate; my friend's R34GTT in AUTO with nothing but a Std ECU ran 194rwkw and the curve was A LOT smoother than yours :laugh:
Glad that my immediate reaction from seeing your graph is shared by a few others.
You have a PFC; your graph should be smooth as all hell!
Nope.
I've never seen someone "average" runs and print that out.
Not saying its not possible... But your run is all over the place which is basically a poor tune
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
