woahhhh...thts awesome dude but a bit overkill jst to fix a groan??? :laugh: I doubt fulcrum would go to those lengths to fix a noise but good on the guys in m'sia! Let us know if it comes back and if it does it might mean something else is the problem. Out of curiousity, did they do all that while you waited?? mines got a similar thing happening, a bit annoying when the stereo's off.
On another note, I reckon T04GTR's post does make sense too but still to hear from him on how its done...for us suspension noobs :)
Yea a bit overkill. I got really worried too when they took apart the whole thing. :P
Yup, waited while they did it. Took them like perhaps 2 hours plus. >_<
But it was ok as I like to be around my car when someone work around it. I like to watch and ensure she is treated like a queen. >_<
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
