Thought it might be better here because most people runninf forced induction are running a PowerFC.
Anyway - My Handcontroller is broken. The Screen works perfect, but the green back light is now very dim. It lights up when I bend the top of the controller a little.
I've had my mate look at it (he's an electronics engineer) and he says the board might have proken. When you bend the little tabs and take the screen off, and put it back on, and maybe move it to one side slightly it works for a few days and then goes out again.
My main question is though - Does anyone know anyone around australia that fixes them?
Thanks guys
Edited by The Mafia
https://www.sau.com.au/forums/topic/138182-powerfc-hand-controller-broken/
we checked all of that, the screen isn't actually soldered on - Its held onto contacts via bend tabs.
I've tried moving it around but if you move it too much it touches other "touch pins" and the screens starts to skew a little.
I've even thought of adding external wires over the circut board to get the power up there. Its power to the back lights, not the screen.
You could probably just use a multi meter to find the live come up the existing wires then just tap into that and re-wire the backlight.
Cubes has his Pfc fixed by force electronics (here in Adelaide) so they would be able to fix the hand controller no probs.
Im suprised your mate cant fix (or doesnt want to :laugh:) but any -good- electronics place should be able to fix it....
Have u seen the controllers with blue led's in them...looks good i think :D nice mod i might do one day
Edited by Bl4cK32
Im suprised your mate cant fix (or doesnt want to :dry:) but any -good- electronics place should be able to fix it....
Have u seen the controllers with blue led's in them...looks good i think :P nice mod i might do one day
awesome.
Do you have their contact details?
My mate could fix it, but its probably better I get some people that have dealt with them before to fix it. He said he could and to bring it back to him if I wanted it to, but he lives next door to my ex girlfriend lol.
And besides, this force electronics place might know exactly what the problem is.
  • 1 month later...
Mine has done this twice, and both times it was when the car has been parked in the sun on very hot days. The screen becomes nearly unreadable. Once it cools down it's fine again... how strange.
no thats a very bad idea because they may use different voltages.....take it to a electronics repair place or if you said your mates a eletronics enginerr he should be able to fix it easy as for you.
no its not a bad idea because you use a multi meter to find the correct voltage.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
