Hope this helps... haven't had time to put it into table format to make it easier to read, but:
Code - Name - Manufacturer - Series 1 - Transition - Series 2
KH2 - Gunmetal Grey Metallic - BASF - Standard - Standard - Standard
KG1 - Jet Silver Metallic - BASF - Standard - N/A - N/A
KL0 - Spark Silver Metallic - Nippon Paint - N/A - Standard - Standard
326 - Crystal white - Nippon Paint - N/A - Standard - Standard
732 - Black Pearl Metallic - ALESCO - Standard - Standard - Standard
AH3 - Red Pearl Metallic - ALESCO - Standard - Standard - Standard
BL0 - Greyish Blue Pearl - BASF - N/A - Standard - Optional
TH1 - Dark Blue Pearl - ALESCO - Standard - Standard - Optional
DH0 - Dark Green Metallic - ALESCO - One Off - N/A - N/A
The last colour was only available on a one off GTR made specifically for the head of the development team (Shizuo Watanabe) responsible for the R32, so not really sold to public, but narrowbody (non GTRs) were available in the same colour.
As for the finding the code, you should be able to read it off the VIN plate, failing that plug the chassis number into Nissan FAST and it'll tell you what it rolled off the factory floor with.
Shan - where did you get that list?
Its in the GT-R Magazine... Issue 49 :dry:
Umm i've got the catalogues for others like the Ceffy and the silvias n stuff at home (in Syd) but I haven't gotten around to translating em.
Its in the GT-R Magazine... Issue 49 :P
Cool
If you get around to translating them - let me know?
:dry:
You can come over n borrow em... I'll be putting up my great wall of japanese mags n catalogues when I get back.
Thanks . Have you got any numbers per colour of car production.
I don't unfortunately, but you're most welcome to plug in all the numbers from BNR32-000001 to BNR32-999999 and start a running tally ;)
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
