i jst bought a set of 18s starcorp impul 9.5" front and back deep dish front and back... i want to know what mods can i do to the front and back guards to get them to fit.... and also i wood lik to know wot is involved in lippin and rollin the guards? i got a skyline r32 gtst
thanks alot guys get back to me
here is a pic of the wheel i got
https://www.sau.com.au/forums/topic/138686-how-do-u-fit-wide-wheels/
wow wouldnt 9.5inch front be a little to big??
I dont think you will get a gd handling out of that.
But then i could be wrong!!
What size rubber you plannin to put on them??
You might have to roll your guards,,
9.5" will fit the back fine with 255 tyres without any modification. i think you'll find that 9.5" on the front will rub without modification. i have 8.5" on the front of my car and they sometimes rub on full lock.
where do u get the rubbin from the inner or outter side of the wheel???
and also wot is involved in rolling the guards??? i dnt get it??? could sum1 plz explain to me or give me a rough idea of how to roll the guards?? i work as a spray painter so i could do the work my self but i jst dnt noe where to start or what to do?
This is how guard rolling is done. I'd leave it to the professionals if I were you as there are not many ppl that can do it properly and you will run the risk of your paint cracking...not so much an issue if you're a spray painter. Oh and you'd be better of exchanging your fronts with 8.5...less hassle and cost to fit.
i still beleive 9.5inch front are way to big..
8.5inch max would be ideal.
i was gettin scrubbing issues with 235s on 8inch rim on the front at full lock. Just hittin the inner guard i think.. But thats easy to solve. Take the black plastic guards out lol..
Hmm i think tempe tyres does it as well lol..
no idea how gd of a job they do, but heard from few ppl on these forums that they got theres done there.
But try fitting your rims first then see whats needed.
you won't be doing urself any favours by having 9.5 all round on a GTST....ur steering will be a lot heavier not to mention more stress on suspension components, possible guard rolling etc...you're mainly concerned bout looks and not handling?
On a GTR yes.
i thought that 9.5" wouldnt clear the front due to caliper clearance. from memory, my 8.5" just clear the front calipers. oh, have fun with handling as well.
Edited by Nozila
My r32 gtst has 8 inch wide fronts and 9 inch wide rears, with 225 and 235/17 tyres respectively. In my case, there is no way any wider wheels will fit with stock guards/no rolling etc.
Brake caliper clearance is another thing altogether, its not s omuch about the width of the wheel, but more the design of the spokes and the offset etc.
i see in the tyre thread that 604cerfiro fitted 17" and 10" wide front and 18' 10.5" rear. check out his pics is it possible???
10 inch rims on an R32?? Easy bro... just check out mine :O. And even better, it's on a GTS-T R32 not an R lol
Skyline model = 1989 R32 GTS-T
Wheel diameter = 17 inch Front / 18 inch Rear
Wheel width = 10 inch wide Front / 10.5 inch wide Rear
Wheel offset = hehehe
Tyre size = 225/45/17 , 235/40/18
Modifications to fit = Rolled / pulled the living hell outta the front & back.
I can bet you a million bucks that 215's can fit on 10 inch wide rims, u just gotta know how to get em on.
Link to pics: http://www.pbase.com/suomyairsoft/new_rims
