As much as i agree i think there would be some that would argue the point with my car..?
Jason, have u done much to the cradle? were going to look at modifying mine shortly, a few photo's we have look like its trying to twist the thing out from under the car..
still sthe standard diff shafts etc never broke any thing
even has the same diff oil it came over to australia with 5 years ago bcaus i have a locker ready to take its place when this diff goes
hi-cas is gone and the pick up point for the hi-cas has been changed so i can put 26x10x15 in rubber under it
if you want i can pm you a pic of what we have done?
  • Replies 48
so far ive only replaced the rear screen with lexan
Thats a good number mate Congrats
two questions though
is the car registered and are u running full trim in it or just the two front seats
Edited by MR331307
gutted interior and the car got defected so the only way i can re register the car is to cut out the rollcage and make it pass an emissions test
lol with indy blue injectors
lol
true
anyways hope to see this thing at the track and hopefully both our cars can go for a run down the strip together
what rwhp on 20 psi were u making
i will be racing again on the 18th november with a bit more boost
after that meeting we are putting wide body rear guards on it so i can fit 28x10.5x15s under its ass
last time we had the car on the dyno it oversped the dyno at 7000rpm for 600rwhp at 15 psi boost but it was an old dyno
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
