Man I'm stupid, finally figured it out. All the pics I keep seeing of the 350gt-8 are the 2001/2002 models. Mine is a 2003 and has had a few changes. I found this on the nissan global site:
Skyline Sedan Undergoes Minor Model Change
Among the refinements made to the Skyline Sedan this time, the 2WD models now have higher spring rates, shock absorbers with approximately 30% greater damping force and larger-diameter stabilizer bars for better control of body motions, compared with the previous models, and thereby deliver a tauter driving feel. In addition, braking performance has been enhanced by adopting a braking system incorporating high-performance sport brake pads with an increased friction coefficient and highly rigid brake rotors with an outstanding heat radiation characteristic.
The exterior design projects a sharper impression than before as a result of applying a smoky chrome finish to the grille and headlamp inner panels and changing the sill color from gray to black. At the rear, the car badge and Skyline emblem have been repositioned to give the rear-end a wider look.
On the inside, the audio and heater control switches have been embellished with a chrome accent for a higher quality image, and the 250GT and 250GT FOUR models are provided with rear-seat air-conditioner vents for enhanced occupant comfort.
The grade selection has also been reorganized as part of this minor model change.
<Major specification and equipment refinements>
Exterior
Repositioning of the rear car badge and Skyline emblem
Refinement of the design of the radiator grille, headlamp inner panels and sills
Addition of Sparkling Silver Metallic and Rose Red Pearl as new body colors for a choice of six attractive colors altogether
Interior
Refinement of the control switch design
Adoption of sun visor extensions
Addition of a light to the front-seat vanity mirrors
Adoption of a double-pivot rear-view mirror
Expanded application of rear-seat air-conditioner vents to the 250GT and 250GT FOUR models
Mechanisms
Refinement of the suspension and braking system
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2591299
yeah i saw one of these on the road a while ago, and it threw me. didnt know it was a skyline till i saw the badge. looks more like the new maxima or something.
what engines do these have? turbo? i know i could google it, but meh.
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2604721
ok, i cracked and googled, lol.
3.5L DOHC V6 NA. meh. i dont really like it. very family/maxima. how can they call this a skyline????
VQ35DE (NEO) type V 6 cylinder DOHC with an X toroid CVT 8 speed transmission.
It's more than worthy of the skyline name and is totally different to a maxima.
I parked mine next to a maxima the other day and they look totally different.
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2606849
id get the coupe - but its similar to the 350z i reckon.....bah just slap on a turbo when modding it - works well either way....
Edit - ok maybe interior is not that much like the 350z - i dunno...gives me the impression that one of them was trying to copy the other....
Edited by emsta2003
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2606996
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
